Where did gnome tweaks go? I can't find it. And Stacer also can't be find. Where did they go?
Or just type tweaks
I admit, the software center search function, could use some improvement. If you run a Google search online, even if you typed something not 100% correct, Google will get you there anyway. I'd like to see search function in software store improved.
Then what is my problem? And how can i solve it?
If you had put a hyphen in between gnome and tweaks it would have shown. You could have used the terminal command of:
sudo apt install gnome-tweaks
You don't wrote it the Way that the Sodtware Center can detect it. Use gnome-tweaks or only tweaks instead or the Terminal with the Command what @swarfendor437 wrotes.
Did i write stacer wrong? This is a fresh install of Zorin Os 17.3. Something is not right with debian packages.
Guys, I hate Windows. I don't want to go back to it. But there is something wrong about deb packages in Zorin 17.3 with a fresh install. I love Zorin OS and bought it. Somebody help me?
This Program wants qt6 Packages/Dependencies but these are not available in Zorin 17/Ubuntu 22.04. Did you downloaded this Package from the Developer? If yes, look if they offer a suitable Package.
When You go to Software & Updates and there in the first Tab. What Source is set up there? The Main Server or a local Server? Did You added other Repo's? Please take a Look in /etc/apt/sources.list (this is a File) and /etc/apt/sources.list.d (this is a Folder) and post what is inside it.
When you have bought it and use the Pro Version you also can get personal help on this way:
Can you go to Software -> Software Repositories, and share a screenshot of that window? Make sure to maximize it as not everything will fit otherwise. You should see something like this:
Everything seems fine from that end. Try running sudo apt update in a terminal window, and let's see what the output looks like.
I change the server to "Main Server" and it solved. Thanks to everyone trying to help me. I think there is a problem Ubuntu server in my country.
A post was split to a new topic: Unable to install Windows-App-Support
I always tell users to change their software source in the Unofficial Manual.
What is this?
