I have this problem too, but my laptop is Panasonic!
Do you have any solution for me?
My main problem is that airplane mode is keep turning on! And when I used the line that you mentioned in terminal, less that a minute it turns on again.
Also my laptop has a physical key for WiFi.
If the physical switch is not making any difference, it may be that your ACPI tables are not being properly translated. This often relates to how they were written for Windows OS, then never really updated by the manufacturer.
You can use a couple of Grub Parameters to delegate how they should be read on initialization and this should work for either wake from sleep or boot:
acpi_osi=! acpi_osi='Windows 2009'
To add them, let's use the text editor in terminal just for ease and speed:
sudo nano /etc/default/grub
arrow key down to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" and add the above parameter. It will then look exactly like:
Note the single tick quote marks. Those are important.
Once done, tap the keyboard shortcut ctrl+o to overwrite, then enter to save current configuation, then ctrl+x to exit the editor.
Now, you must run
sudo update-grub
in order for the changes to take effect.
You must reboot, check the physical switch is off... then Reboot again... and test wifi.
