All laptops TVs using 5ghz without any problem only mac
Hardware ![]()
But if i talk about hardware , if it was not made for 5 ghz , why and how did it connect it's a mystery and a very old laptop even older then this mac can smoothly connect to 5ghz with out any issue it was running zorin os 15 lite
I have no idea about the older mac or the mac os franchise, Bu it is mostly the hardware that gives the user ability to connect to a particular band of network, You can somehow manage a 5ghz dongle and check if the issue continues.
The network connects, but the user usually faces some problems or simply for ex:- a 300 mbps networks cuts to a 150, which is quiet smooth ![]()
So basically we can connect but the user will face problems
Yes, In most Cases.
