By the way, is there any remote desktop like that in windows, I am wondering to connect to another pc by remote desktop but I cannot find it on Zorin
I use VNC to remote into our Wordpress server on the same network.
https://www.realvnc.com/en/connect/download/viewer/
It is free for a personal use.
I should have asked you to try the different the USB port ![]()
As you just experienced not all USB pots behave the same way.
I will mark this thread as solved so that the people with the same problem can find this thread easily.
A post was split to a new topic: Initramfs error
When you don't suggest it, it works.
When you do suggest it, it doesn't. That's the forum.
If you are at a bus stop waiting on the bus- Light a cigarette to make it show up.
A post was split to a new topic: Keyboard shortcut not working
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
