I tried this one but no use.
This clarifies it is not desktop related...
What is your output if this terminal command, again?
sudo lshw -C network
jeslin@jeslin-Satellite-L510:~$ sudo lshw -C network
[sudo] password for jeslin:
*-network
product: RTL810xE PCI Express Fast Ethernet controller
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 02
serial: 00:1e:33:f9:e0:4c
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.11.0-36-generic latency=0 link=no multicast=yes port=twisted pair
resources: irq:16 ioport:2000(size=256) memory:d0410000-d0410fff memory:d0400000-d040ffff memory:d3600000-d361ffff
*-network
physical id: 2
bus info: usb@2:3
logical name: usb0
serial: a2:3c:ce:3b:6f:a6
capabilities: ethernet physical
configuration: broadcast=yes driver=rndis_host driverversion=5.11.0-36-generic firmware=RNDIS device ip=192.168.42.67 link=yes multicast=yes
Can you try this driver for it?
Install instructions included in the link.
That shows as the correct driver for your device;
Have you restarted the network manager?
Restarted network manager, but did not work. Restarting the laptop gave the problem a punch on it's face and knocked him off
(I just mean that it solved the issue). Now I feel like there are more options in the menu.
A post was split to a new topic: No wifi icon in taskbar Zorin 16 Core
