You must shut down the computer, then boot into your BIOS / EFI Settings on the Motherboard (not the OS) and navigate to the Security tab, I believe. It varies a bit from one computer manufacturer to another. Look for "Secure Boot" and there should be an option of "enabled" that you can hit enter key on and change to disabled. Then boot normally back into Zorin and pick up where we left off: Adding the Repository above.
It worked! I am now using wifi. Thank you so much for your time and patience. You were very helpful.
Tell all your friends.
"That Aravisian guy... He's just the Bees Knees..."
Will do!
A Bees Knees (or Bee's Knees) is a Cocktail made with Gin, fresh Lemon_juice, and Honey. It is served shaken and chilled, often with a Lemon_twist.
The name comes from prohibition-era slang meaning "the best".
A post was split to a new topic: Fresh install Zorin OS 16 no Wifi
