I can’t able to connect wireless internet connection. Even i can’t find the option in settings. Only USB tethering is works but I can’t able to connect my mobile hotspot internet and wifi with my laptop. How can i fix this ???
@Shiva Hi and welcome to the Forum.
Which version of Zorin do you have e.g. Core or Lite.
Do you know what wifi adapter your pc has?
After you installed Zorin, did you set your software update source to "Main Server" instead of country server.
Maybe this item will be of help or give you a lead to a solution:
or this:
