Although my wireless driver is installed, it is not in use. How can I fix?
It appears to be stating that it is using the driver that came from the kernel and not the one with proprietary blobs on. Is your wifi working? It does not indicate that the Wifi is not in use, just the proprietary driver.
In terminal write: sudo apt-get install mokutil && mokutil --sb-state
If secure boot is enabled disable it in bios and run this command.
In terminal write: sudo apt-get install rtl8821ce-dkms
The OP snapshot clearly states the DKMS driver is in use!
The driver is already installed but it's awfully bad (coming with Linux kernel). I thought it would be better if the proprietary driver was installed.
I knew it had to say "1 Proprietary drivers are in use" for the driver to be in use.
Hello! The driver has been placed in the standard repository, so you just need to run the command:
1 sudo apt install rtl8821ce-dkms
Yet another looping phenomenon is observed ![]()
I know we all should scroll up, but sometimes there are too many questions on the forum. I can hardly catch up sometimes.
beep beep... Я робот
added name of WiFi chip to the title
mission completed
beep beep.....
6 posts were split to a new topic: WiFi driver in Live but not after install
Marked solution. 212
