Hi, I installed the Workspace Indicator extension. However, after reboot, the indicator doesn't show up. I had to disable the extension and then re-enable it for it to show up. What's going wrong here?
Does it fail to appear after every reboot?
Yes. It's failing.
Any solution for this?
You might review the tips here:
I am not sure why one gnome-shell extension may fail to autostart.
Which folder do I need to delete to reset the workspace settings instead of deleting all cache?
I would suspect these configuration files are stored in ~/.config
You can test this easily by renameing ~/.config to config-bkp and then log out and in or rebooting. You can restore the config directory by removing the system created replacement and renaming the config-bkp back to .config.
Marked solution. 157
