Zorin 17.3 pro BlackView AceBook 12: HowTo deal with Cloudflares Turnstile error: 600010
Hi,
i am coming back to my problem that my machine is only willing to load the Mesa Intel Iris Plus Graphic time by time - no glue why. But this is not the topic, we discussed this some time ago here
As workarround i load in recovery mode. This was doing fine for month. Now it looks like this workarround leads to a new problem: Cloudflares Turnstile error: 600010 on all clean chromium installs on my machine.
It looks like this can be connected to my workarround (recovery), OpenGL3 is not more handeled properly by chromium. Firefox is doing fine instead on the same machine, i tested Chrome on a different Chrome OS machine as well without probs.
Does any have a glue if loading kernel in recovery could be the root cause of this stupid turnstyle error ?.
BTW
I have a long discussion to investigate with the siteowner, cloudflare is pushing back by default.
I put this to Hardware because my assumption is that this is connected to my unlikly hardware issue which leads to recoverymode.
It is not my intention to start a discussion on cloudflare and the turnstyle error 600010.
THX
How is Chromium installed? As Flatpak?
yes, all three chromium versions (google chrome, chromium, ungoogled chromium come) are flatpak installs
Have you ever tried Zorin 18 to see if it works better with your hardware?
... thinking about, basicly i planed to watch out for 18.2 to be released as everything (was) wirking fine
Then, I would suggest to try the .deb Versions. Google Chrome offers it directly:
For Chromium and Ungoogled Chromium is it a bit difficult. There is a Third-Party source that offers both:
thx, just tried .deb version, unlikely no change, error remains
final last words
couldnot solve the prob, but it looks like that turnstyle is anyhow depending on OpenGL3 .
UPDATE 260902
further investigation outcome is, the issue is for sure connected to OpenGL/Canvas Graphics. I could rebuild the site behavior while enabling/disabling OpenGL/Canvas. So it looks like that the turnstyle script is unlikely trying to identify the user on machine level, in best case as workaround to identify a bot. At the end, its about security and privacy. Meanwhile Cloudflare is offering turnstyle for free which leads to more and more usage/probs with this. Thats why i had to investigate deeper, out of this i could focus the root cause.
This issue is not connected to my first thought about my hardware and the loaded kernel. Thats why i moved to general discussion and adapted the title.
So again, Cloudflares Turnstyle is different topic not connected to Zorin. So no turnstylediscussion here. Hoping helping out someone else with this.
Some Browser recommendation is LibreWolf, the secured FireFox. LibreWolf allows to configre OpenGL / canvas per site. So by default disabled, your machine can not be identified without your permission.
thx for your support which helped out to allocated the rootcause and based on this finding a valid solution, not to forgot thanks to zorin
