On my Blackview Acebook with Intel Mesa Grub doenst want to load Mesa Intel Iris Plus Graphics. Instead llvmpipe (LLVM 15.0.7, 256 bits) is loaded. To start up i have to enter recovery mode, otherwise the screen keeps dark. In a view cases the correct driver is loaded from startup. Tryied to fix this with modifying grub on startup, unlikely no change of behavior. The system is up to date, all drivers are updated. Changing Windows from Wayland to X11(Xorg) doenst help out.
Any idea to fix this is welcome. I dont kow why loading Mesa Intel Iris Plus Graphics fails. HW is an Blackview Acebook12 with Intel environment.
You have really new hardware. I'd try it with the newest kernel so that the drivers are included. You can install a newer kernel e.g. 6.16 or 6.15 easily with the cappelican mainline installer tool:
thx - updated from 6.8 to latest available 6.12 - in the first shot it looks like the prob is solved - maintaining if this will be stable. As of now i untouched MESA
Additionally the F-buttons do there job like brightness- and volumecontrol
Big thx to Forpli & swarendor437 - unbelivable support in this forum
Admittedly, the current default is that it will boot to the latest installed kernel.
The only need to change that is if a user is relying on an earlier kernel, but does not wish to try to block later kernel upgrades.
Thanks for the correction! This means that you only have to set an older kernel to default if it has been replaced by a newer kernel, e.g. through an update or upgrade.
If you install Zorin 17.3 and then manually install an older kernel such as the 5.15 kernel, then you don't have to do that either?
@Aravisian Do you know if kisak mesa fresh ppa can still be used in Zorin 17.3 as it is based on kernel 6.8 (the same as in ubuntu 24.04 which is supported) although support for Jammy/ubuntu 22.04 has been discontinued?
The Ernst PPA is the Unstable newer Beta packages - which may help those with the Newest Hardware - and some people just... believe that the later package always equals good and better, not matter what.
That said, the user needs determines which they should use. Just as long as they are aware that when using the later Unstable Packages, they may find themselves to be Bug Testers.
