When my laptop is in sleep mode and i lift lid to awake Zorin 17 it freezes and crashes and i have to force reboot. It doesn't happen every time but yea.
The first thing I would try is:
sudo nano /etc/systemd/logind.conf
Arrow key to
#HandleLidSwitch=suspend
Remove the hashtag and set to ignore
HandleLidSwitch=ignore
Tap ctrl+o
to overwrite, then the enter
key to save current configuration. Tap ctrl+x
to exit the editor.
Ok i did that.
Now, it is just a matter of testing to see if it happens again...
Yea for sure, I'll keep you posted. Thanks again.
Ive tried it twice and it hasn't crashed. Hoping this stays fixed now, and thanks for fixing the thread title.
4 posts were split to a new topic: Zorin OS 17 desktop crashing when wake
