I started Zorin Connect on both my computer and my Android app. On both devices, it won't show the other one. I tried it with VPNs disconnected, I connected the devices with a cable, nothing works. Any guesses what the issue might be?
Hi, take a look at my tutorial here:
For security you should have ufw (uncomplicated fire wall) and it's gui, gufw installed. Launch via the terminal using the command:
gufw
you will be prompted for your password to give you root access.
It will show up as turned off - turn it on.
Once ufw is turned on you will notice that all incoming traffic is blocked. Click on 'Rules' Tab then click on the '+' sign bottom left. A new interface opens:
[Screenshot from 2023-01-02 12-54-23]
Go to the Application field and scroll down either…
If still an issue, try disabling the firewall but do so at your own risk. This is what I had to do to get KDE Connect to work in MX-Linux KDE 23.1!
both the devices need to be connected on the same wifi
