At one time, it worked. When I first installed Zorin. I came back today because I wanted to transfer some files and can't do so via USB. (Long story.) But when I turn on Zorin Connect, and also KDE, my android doesn't show. When I look on both KDE and Zorin on my laptop, my laptop doesn't show. Literally nothing anywhere.
And here's the newb part: I have zero idea how to connect one to the other via IP -- but I kind of suspect it wouldn't even let me if I did. HELP!
I installed KDE after Zorin wasn't working. I tried uninstalling via the store but it still remains. #newb
I literally don't know how to add a device by IP. I don't know my computer's IP or how to find it. I've tried Googling, but seems like everyone says something slightly different.
Does my phone have an IP address? What's w/ with 1716 -/+ on the laptop client? No clue wtf I'm doing.
Tried to most common. Wound up with it being "added" in my app, but then it doesn't do anything. If I tap on it it, it just let's me edit the IP address. Still nothing in devices anywhere.
192.168.1.1 is your router. Your network DHCP allocated IP is the last one, 192.168.1.21.
If you have activated the firewall, you need to add the predefined rule to allow Zorin connect through the firewall. I will come back with the Tutorial I posted shortly.
To find the IP address of your phone, open up Settings and then select "About phone", scroll down until you find IP address.
