My zorin reset them and it doesn't turn on anymore. Letters appear after being turned on. What can I do to get it back without having to format it?
I am assuming this is due to a Sticky key. [Ref: Bootloop issue - Zorin lite]
Boot up your machine
When the letter starts printing press n hold
ctrl+alt+del
It will take you to grub menu, Select "Start Zorin"
If it boots up then you can confirm that it due to a sticky key. In this case you have to find out which key is causing the issue to fix it.
If it still doesn't boot then let us know.
thank you my friend. My Zorin is working again.
