Hi
I want to install zorin 15.3 lite for 32 bit system I booted it with Rufus and in bios I clicked on try or install zorin and then it is showing ZORIN on screen and got stuck for about 3 hours and then I just turn off the pc
Hi and welcome to the forum.
You will find some basic essential installation checks and advice here: Before you install
If you have done those things and still have the problem, post a screenshot of what comes up.
