I tried alot for correcting the system and nothing worked. So went for fresh install of core. But system is slow , so installed lite version as per the above instructions. I don't want other desktop environments take disk space
Why not burn a Zorin Lite .iso instead and install lite? You don't have to install core to use lite.
By mistake, It happened that way
Now want only lite not core. Help me remove core
There are previous threads about how to replace Core with Lite. e.g. How can I replace Zorin Core with Zorin Lite?
Make sure you first backup your /home partition containing personal files etc.
