Cuz with the dvd I downloaded the iso from pc and it's the same problem
So what is the solution?
Hello !!
In that case, try downloading it from a Different Mirror.
I was called away to determine an issue with a Toyota Camry that pulled in.
I Volunteer my time and responses here and am at no ones Beck and Call.
What's the different mirror??
Cuz I checked the checksum and it was the same
On the Zorin OS Download page, you can click on issues while downloading?
button to select a different mirror:
Which mirror you suggest?
You might try any of the European ones.
Okay I will try thank you.
What if this didn't solve it??
Try checking your hard disk.
How??
I tried this "quiet splash iommu=soft acpi=off Tap Enter key" with the dvd and it didn't work why??
I went to Zorin and download from site to a usb early this morning to see about the file .
Installed in a Hp G42-415DX I have laying around. Install went fine no issues so I don’t know what the problem is you’re having if you have re download the file.
Apparently there is a issue with your laptop as this dual core is much older I have use to run
Why are you still using the DVD I thought you mentioned downloading it on usb?
Try a different name maybe yefsah7734 or pleasework1234
it didn't work all
Try Helpme1234 uppercase first letter
No hhhhh it must start with lewer case letter
I solve it now, thanks
Try a12345678
Yahoo!!!
