That's the right direction after it checks you should be going to install ...
It's 3h now and it's arrrive to 52%
Your system with only 6gb RAM it may take a while. Let it run its course .... find something to occupy yourself with and make checks every so often and see how it goes.
It can be frustrating but once installed you should enjoy it.
Edit: Hey, look at this way your over halfway there
Okay thanks
Sorry, I had needed to leave earlier.
Okay, welcome
Looks good.
Once installed, we may need to set the grub parameters as permanent so that you do not need to mess with that anymore.
Okay I will tell you when i complete it
Sometimes it is so tough to wait...but your almost there! Congrats
Look :
After it finished installation and restart and removing the installation media:
What is that ?
That generally means that the Installation medium is corrupted.
This sounds familiar...
Have you been using the Same USB stick this entire time?
Are you using a Download Agent to download Zorin OS .iso?
No I downloaded it from phone and copie iy to pc, why??
So what you think what's the problem?
Maybe it is the Phone Transfer that is causing it...
I don't know maybe the usb drive??
Cuz it's the same problem with the dvd.
Think and tell me
