Hello can you help me?
Do not boot with Safe Graphics.
I tried install it with the first option the normal option this time and is happened.
Not duel boot, zorin only.
IMG_20220311_210605
I waited and the laptop turned off.
I did everything, chesum, flashing ...
Some time has passed and my brain has cleared the cache.
Can you remind me what the issue is with normal boot?
I tried install it with the normal option this time with a flash drive USB and is happened.
Does virtual machine extensions have any role here??
The safe graphics didn't work too.(I install it but in the end it didn't work after I tried to log in)
Are you installing in a virtual Environment?
Can you tap the e key on the Grub menu prior to that screen where it says to Try or Install Zorin.
This will open the editor.
Scan through until you see "quiet splash"
Add the following parameters, exactly as you see them here after the quiet splash so that it looks like
"quiet splash iommu=soft acpi=off" save and exit out and proceed to attempt to boot.
I'm not installing it from vm
I will do what you said later is this will solve the problem??
Have you ever tried installing a distribution other than Zorin OS before?
Yes, Ubuntu
Tap Tab
On the line showing at the bottom, can you arrow key over to the word "splash" and type in the above parameters?
If not...
What happens if you arrow key the selection to "Try or Install Zorin" and tap the e key?
Let's try that.
Then what?? Please explain to me step by step okay
make it so it looks like:
Tap Enter key
https://help.ubuntu.com/community/BootOptions
If this also fails, then boot and enter your BIOS EFI Settings (Prior to Linux Grub) and check if you are set to AHCI or to RAID.
If set to RAID, try setting to AHCI, then booting Zorin and see if it works.
If set to AHCI, try setting to RAID, then booting Zorin...
Hello are you here??
