Zorin OS 16 not starting
Hello everyone I hope you're doing well. I installed Zorin OS 16 core version on my new ssd and it's working fine. But today I just turned off the pc and now when I try turning it on Zorin doesn't start, it just stays in black screen after Zorin startup logo. I've been searching possible solutions but it seems nothing is really working. Can somebody help me please?
Are you using AMD or Nvidia Graphics card?
You may try holding ot tapping the left shift key at boot to pull up the Recovery Menu
Select Advanced Options for Zorin and then select the Previous Kernel and try booting from it.
Update
https://forum.zorin.com/t/zorin-os-update-after-sept-6-21-kernel-5-11-0-34-black-screen/7816/4
