Tomorrow is the day! Hooray!
The problem the names software what you talking. Not all working with them. This software is some emulations but don't gived you 100% working a software. Besides it difficult to settings then example Lutris. Wine. If Zorin is for beginners then I am ok with that. I know on Zorin very good working Steam with emulation Proton. I am proud the Zorin show me how simple I can changing customization desktop also software what exist on linux distributions. It is very usefull to learning many things. Linux isn't hard to repair what I cannot sayed with Windows this never version. Apple for me is very closed like people in the cave. It is good for people using to them purpouse and they are happy with them.
I will drinking tomorrow cheers for that. I mean fiesta.
So, are we going to be able to use the updater in Zorin 16.3?
And would going for a complete reinstallation still be a lot better over all?
Yes, the Zorin Upgrader Tool will work for upgrading Zorin OS 16 to Zorin OS 17 directly without performing a fresh install.
I always recommend it. While the Direct Upgrade has its perks, it is a time consuming process (taking several hours as opposed to a fresh install taking thirty minutes or so) and any repositories or packages installed that are not upgradeable to Jammy may break.
A fresh start does wonders.
Yes, I was afraid to hear that.
The problem is, I spent quite a few hours during last week making everything fit like a shoe, including the GUI setup, fiddling with extensions, getting WWAN to work, you name it.
I am wondering if reconfiguring all that (if I can even piece it all together again) will take longer than the direct upgrade. After all, however long it might take, it can just chug along on the side and will likely require less interaction, no?
If you have the time to kill and a good book to read (Or doom scrolling on your phone), you might just test the direct upgrade and see if everything (any additional extensions you installed) still works. If so, consider it a win and the boon of Zorin OS now offering that option.
But if not, fresh installation can be a fallback.
As I plan on having ZorinOS 17 on my main computer for the foreseeable future, I plan on doing a fresh install.
I have 16 just the way my family likes it, but after playing around with the beta, it will be no problem to recreate what I have in 16 again in a few minutes. Maybe even make a few changes that will enhance everyone's experience.
I will just make sure I have the few things I need backed up, then I can be sure I have a fresh install for the future.
This seems like the cleanest way to go.
Just backup all good things and then installation fresh installation. I remember harvey or storm I don't remember exactly,remember he put guide how to backup home partition, without delete them and installation a fresh installation Zorin OS.
I remember when Windows was on the earth, the fresh installation was normal for us ,when coming up new version. I know i remember when I updated mint,this also was problem with some package and mint was more unstable.
Mint's upgrade tool on LMDE and the Ubuntu version work great. I suspect it will work just fine for Zorin too.
IT'S OUT! DOWNLOAD IT NOW!
https://mirror.webworld.ie/zorinos/17/
For me "17 is OUT...."
...when the Pro is available and upgradable flawless from 16.x
PRO will be available later this day when devs will update ZOS website page, atleast CORE is ready
I will also wait for the Pro version and then install it directly on my four systems. While I don't need most of it, I believe one can financially support open-source projects when satisfied with the software.
How it is ?
Waiting for PRO release (cause i need that Win11 layout)
You sure, they are releasing Pro today already? That would be awesome.
on their Twitter latest post they said yes
where is the pro version? I can't wait any longer
probably around 6 PM ( Europe time )
