Hi everyone!
This week I tried to install Zorin OS 18.1 alongside my Windows setup, but I cannot boot into the system normally. To successfully boot and reach the graphical interface, I am forced to use the following parameters in GRUB:
*** nomodeset**
*** processor.max_cstate=1**
These parameters were suggested to me by the Google AI browser assistant, which has been guiding me up to this point. However, it couldn't find a solution beyond this. The AI believes it might be a kernel incompatibility with the processor or something similar.
Because of nomodeset, the system does not load the integrated graphics drivers for my Ryzen 7 5700G, leaving me without hardware acceleration (rendering via llvmpipe). If I remove these parameters, the system freezes on the boot screen right after the Zorin logo.
Can anyone provide a tip or point me to a tutorial? Thank you.
Below is the complete hardware information provided by inxi -F --filter:
System:
Kernel: 7.0.0-31-generic arch: x86_64 bits: 64
Desktop: GNOME v: 46.0 Distro: Zorin OS 18.1 noble
Machine:
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS_BR v: Rev X.0x
serial: UEFI: American Megatrends v: 4021
date: 08/09/2021
CPU:
Info: 8-core model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64
type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 2430 min/max: 422/4674 cores: 1: 2994 2: 2393 3: 2393
4: 2393 5: 2393 6: 2393 7: 2393 8: 2393 9: 2393 10: 2393 11: 2393 12: 2393
13: 2393 14: 2393 15: 2393 16: 2393
Graphics: Connected to a non-smart TV.
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
driver: N/A
Display: wayland server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: X: loaded: modesetting
unloaded: fbdev,radeon,vesa dri: swrast gpu: N/A
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: swrast platforms: wayland,x11,surfaceless,device
API: OpenGL v: 4.5 vendor: mesa v: 25.2.8-0ubuntu0.24.04.2
renderer: llvmpipe (LLVM 20.1.2 256 bits)
Audio:
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
Device-2: AMD Family 17h/19h HD Audio driver: snd_hda_intel
API: ALSA v: k7.0.0-31-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Network:
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac:
Drives:
Local Storage: total: 3.66 TiB used: 12.13 GiB (0.3%)
ID-1: /dev/nvme0n1 vendor: Seagate model: XPG GAMMIX S41 size: 953.87 GiB
ID-2: /dev/sda vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB
ID-3: /dev/sdb vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB
Partition:
ID-1: / size: 366.88 GiB used: 12.1 GiB (3.3%) fs: ext4 dev: /dev/sdb3
ID-2: /boot/efi size: 96 MiB used: 37.8 MiB (39.3%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
System Temperatures: cpu: 33.6 C mobo: N/A
Fan Speeds (rpm): N/A
Info:
Memory: total: 28 GiB note: est. available: 29.16 GiB used: 4.08 GiB (14.0%)
Processes: 377 Uptime: 1h 34m Shell: Bash inxi: 3.3.34
Thanks in advance for any help!
SUMMARY of what the AI did:
- My first boot attempt simply looped back to the installation menu and wouldn't proceed. I fixed this by applying DD mode in Rufus with a second ISO downloaded from the official site;
- In the BIOS, Secure Boot was changed to "Other OS", CSM was disabled, and 1st Boot was set to the USB drive -
UEFI: USB DISK 2.0 PMAP (7.7GB). This did not solve the boot issue. It froze at 78% during themd5sumscheck (specifically verifying theinitrd.zstdfile).Ctrl+Cdid not respond; - I selected the "Safe Graphics" option for the installation, but it didn't work either. Then, I pressed
Eon this option and addednomodeset processor.max_cstate=1to the end of thelinux /casper/vmlinuz...line, and it successfully booted; - Inside Zorin OS, GRUB was modified (
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash processor.max_cstate=1"), but upon rebooting, after the Zorin logo, the screen went black (active, receiving signal, but no picture) and stopped. The Blind Terminal (TTY) viaCtrl+Alt+F3did not appear; - Booting back into Zorin OS using
nomodeset, I ransudo nano /etc/gdm3/custom.confand uncommentedWaylandEnable=false. It did not work, andnomodesetwas still required; - Next attempt:
sudo rm -rf /var/lib/gdm3/.config/mutter/sessions/*, but it didn't work; - Next attempt:
sudo systemctl restart gdm3, but it didn't work; - Next attempt: added
amdgputosudo nano /etc/initramfs-tools/modulesand ransudo update-initramfs -u -k all, which didn't work; - Next attempt: set
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash processor.max_cstate=1 amd_iommu=on iommu=pt"; - Next attempt: ran
sudo update-initramfs -u -k all; - In BIOS: Set UMA Frame Buffer Size to 2 GB.
Notes:
- Each of these steps was performed by reverting the previous step, updating, and applying the new commands as guided by the Google AI assistant. However, whenever
nomodesetwas removed, it always failed. Removingprocessor.max_cstate=1and keeping onlynomodesetalso fails. Finally, the last attempt wasGRUB_CMDLINE_LINUX_DEFAULT="quiet splash processor.max_cstate=1 pcie_aspm=off", which did not work. Therefore, I kept bothnomodesetandmax_cstate=1active permanently. - I do not use a dedicated PC monitor; instead, I use a non-smart TV (60Hz) connected via an HDMI cable.
