Zorin os completely freezing including mouse every few hours, requiring reboot
so i have just installed zorin os 18.1 core. have a zenbook 14 ryzen ai 5 340 with radeon graphics, 16gb ram. i am currently running zorin os as a dual boot alongside windows 11, and since ive installed the OS, every few hours, the entire display freezes, keyboard, mouse nothing works and i have to force restart the laptop. using Alt + print + R E I S U B does work to restart, its either that or pressing and keeping the power button for a restart.
how do i fix this issue.
Hello and welcome,
Read this it could concern you with your AMD GPU
oh okay, i ran the commands mentioned in that post, is there a way for me to run a test to confirm the issue is gone or ill just have to wait a day to see the results?
Give me the output of this command in terminal
apt-cache policy linux-firmware
apt-mark showhold
linux-firmware:
Installed: 20240318.git3b128b60-0ubuntu2.26
Candidate: 20240318.git3b128b60.0ubuntu3.1
Version table:
20240318.git3b128b60.0ubuntu3.1 500
500 Index of /ubuntu noble-updates/main amd64 Packages
500 Index of /ubuntu noble-updates/main i386 Packages
*** 20240318.git3b128b60-0ubuntu2.26 500
500 Index of /ubuntu noble-security/main amd64 Packages
100 /var/lib/dpkg/status
20240318.git3b128b60-0ubuntu2 500
500 Index of /ubuntu noble/main amd64 Packages
linux-firmware
perfect, now of course you will have to wait but I think your freeze problem will be gone, I had the same problem and since 2 weeks none freeze and my computer is alive 24/24 :wink:
ah ok thank you so much!
@Nourpon might already have found the actual Issue, but to check some other Points only the be sure:
  • Is Your BIOS in UEFI or Legacy Mode?
  • What Tool did You use the create the Bootstick?
  • Is Fast Start-Up in Windows disabled?
thank you so much but my problem was solved, it was an amd gpu issue
So how was it fixed. Replaced the GPU? changed kernel version? Be nice to know and to inform others.
You could then mark your post as :white_check_mark:Solution.
Thinking it was Nourpon's post that did it
I think it too
yes it was what nourpon mentioned. i ran the commands mentioned in the post, and the issue was resolved
