Everything was okay, but after some rip update it's very difficult to use zorin os Core without getting irritated to the point I shifted to windows.
Everytime I shut down Zorin Os. It stucks on black screen and doesn't turn off the device until power drains completely.
Similarly with restart, it doesn't restart but does the same when I click it stucks on black screen.
Same with suspend, after coming back and reusing the laptop thinking it would happen but nope it won't. A black screen stays forever where nothing works.
Please try booting from an earlier kernel like 5.11.0-44 and see of resume from suspend then works. If it does, the 5.11.0-46 kernel that came through a recent update may have regression.
I tried every kernel version in zorin advanced option all are behaving same for me, I'm not sure what's the reason behind but I have a clue that I recently installed tlp but now I deleted it still the problem perisist. If anyone have any idea to fix please recommend.
It is actually confirmed that kernels 5.13 on Ubuntu LTS (and thus on Zorin 16 too) DO have a regression.
It causes issues with reboots, power offs, hibernation and AMD SensorFusion Hub (on Ryzen-powered laptops, like my HP ENVY).
The issue is fixed, updated kernel is scheduled to be released by the end of January.
I confirm that using older kernel 5.11 continues working nicely, without issues.
I just wanted to confirm, whether you are using an AMD-based system, since these issues are especially seen on AMD-based laptops...
...although your system is not Ryzen, but built on older AMD technology, which is... interesting...
Anyway, thanks for the confirmation
is there way to remove all updates and get back to the default one that comes with it zorin os cause it's so pretty much unusable now, also screen stucks randomly.. rip
Hello, this doesn't fix the issue unfortunately. I checked my kernal version it's 5.16 and tried restarting and it stucked with black screen...........
I have a update available hope it fixes the issue.
Hi, I tried 5.8.0-63-generic............
and it fixes the issue but when I reboot it gets back to 5.15 kernel
I did exactly what you shown in tutorial like boot into you desired kernel then change default=0 to default=save and also add new line then I saved it also did grub update then don't know it's still not my default kernel
