17.1 battery life
Hi
I use the pro at home and the core for work.
I do the upgrade from 16 to 17.1 on my Lenovo P14s (work computer) and since the computer's fan turn everytime, loudly and extract very hot air. Before it's not the cas. And the worst is the battery life. Before it's not like with Windows (dual-boot) but it's was correct. Now I can use the laptop one hour max.
As you can see I have a CPU to 100%
Sometime it's CPU 6 or 8 or 5. But now I do nothing. This computer are amazing but why a CPU to 100%. I just do a post on Zorin forum now...
Do you have any idea of one solution or I have to format and reinstall the 16 ?
Thank to all.
Did you control the ''Process'' Tab if there are any Programs that could be responsible?
Yes, but... no. Nothing strange.
What is your output for
uname -r
and what is the make and model of the notebook computer?
Hi, Aravisian,
6.5.0-25-generic
Lenovo ThinkPad P14s Gen 3
32,0 Gio
12th Gen Intel® Core™ i7-1280P × 20
NVIDIA Corporation / Mesa Intel® Graphics (ADL GT2)
I hope it's helpfull.
Can you please try upghrading to the 6.7 kernel and testing it (Secure Boot may need to be disabled in BIOS EFI settings):
sudo add-apt-repository ppa:tuxinvader/jammy-mainline
sudo apt update && sudo apt install linux-generic-6.07
Reboot and test...
Hi,
I add the first one wihtout problem but the second one have some error at for some package ''not installable''
But for now It's still the same after reboot. 30 min work and 30% battery out... And I just do mail via Ferdium. Before the upgrade it's not like this at all.
Just in case, since the upgrade I have this message with the session opening :
A falure to update some package... Maby it's help.
Thank again and have a nice day.
It's so strange. Before this upgrade the battery was full in 1hour max, now it's 2 or 3 needed and we never had 100% only 99%.
If I don't have solution this week end I format to but another distro for testing.
Did you upgrade from 16 to 17 with Zorin Upgrader? That may be the cause.
Agreed, Package failing to update and the kernel claiming to be uninstallable...
@Guillaume, please check your sources:
The upgrader may have left some Focal Sources listed.
Okay strange...
I send you the source list but yes I do via the GUI and not via cmd.
# deb cdrom:[Zorin-OS 16.3 Core 64bit]/ focal main restricted
deb http://be.archive.ubuntu.com/ubuntu/ jammy main restricted
# deb-src http://be.archive.ubuntu.com/ubuntu/ jammy main restricted
## distribution.
deb http://be.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
# deb-src http://be.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
deb http://be.archive.ubuntu.com/ubuntu/ jammy universe
# deb-src http://be.archive.ubuntu.com/ubuntu/ jammy universe
deb http://be.archive.ubuntu.com/ubuntu/ jammy-updates universe
# deb-src http://be.archive.ubuntu.com/ubuntu/ jammy-updates universe
## security team.
deb http://be.archive.ubuntu.com/ubuntu/ jammy multiverse
# deb-src http://be.archive.ubuntu.com/ubuntu/ jammy multiverse
deb http://be.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
# deb-src http://be.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
deb http://be.archive.ubuntu.com/ubuntu/ jammy-backports universe multiverse main restricted
# deb-src http://be.archive.ubuntu.com/ubuntu/ jammy-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu jammy partner
# deb-src http://archive.canonical.com/ubuntu jammy partner
deb http://security.ubuntu.com/ubuntu jammy-security main restricted
# deb-src http://security.ubuntu.com/ubuntu jammy-security main restricted
deb http://security.ubuntu.com/ubuntu jammy-security universe
# deb-src http://security.ubuntu.com/ubuntu jammy-security universe
deb http://security.ubuntu.com/ubuntu jammy-security multiverse
# deb-src http://security.ubuntu.com/ubuntu jammy-security multiverse
@Guillaume, please post the terminal output of
ls /etc/apt/sources.list.d
google-chrome.list
google-chrome.list.save
oem-sutton.simon-abdukrahman-meta.list
oem-sutton.simon-abdukrahman-meta.list.save
onedrive.list
onedrive.list.save
surfshark.list
surfshark.list.save
tuxinvader-ubuntu-jammy-mainline-jammy.list
zorin.list
zorin.list.save
zorinos-ubuntu-apps-focal.list.save
zorinos-ubuntu-apps-jammy.list
zorinos-ubuntu-apps-jammy.list.save
zorinos-ubuntu-drivers-focal.list.save
zorinos-ubuntu-drivers-jammy.list
zorinos-ubuntu-drivers-jammy.list.save
zorinos-ubuntu-patches-focal.list.save
zorinos-ubuntu-patches-jammy.list
zorinos-ubuntu-patches-jammy.list.save
zorinos-ubuntu-stable-focal.list.save
zorinos-ubuntu-stable-jammy.list
zorinos-ubuntu-stable-jammy.list.save
This one specifically says Focal
These may say Focal, still and the only way to know is to open the file and check.
You can elevate to Root:
sudo -i
Launch the GUI file manager from your elevated Root prompt:
nautilus
Navigate to Other Locations > Computer > /etc/apt/sources.list.d folder and right click each file and check the name and contents, looking for Focal being present instead of Jammy.
You can see how this could be a problem since having two different sources with different dependencies can create conflicts or package deference.
It is not the only One. There are two Others:
Yes, even though they are backup files, it shows a possible discrepancy.
Hi, thank for all your message.
So I change in every file ''jammy'' by ''focal''
When I try to update I get this :
But after a reboot it's different:
And when I do upgrade nothing change.
I still have this at startup and the fan very high everytime.
Maby I dont change correctly every list ?
Thank again.
For your sources, please see here:
The "Could not get a lock /var..." warning only means that you have another package manager open when you tried running the command in terminal. Package management only allows one lock at a time. Closing out the other manager is all that is needed to resolve that.
Number 8 the TuxInvader Repo is still focal. Number 12, 14, 15 and 16 too.
