Bad audio Asus zephyrus g14 2024
this it the stuff will be deleted, is it ok?
I seguenti pacchetti saranno RIMOSSI:
  libnvidia-egl-wayland1:i386 pkg-config screen-resolution-extra
Yes, looks okay for me.
I am installing driver, wait a few minutes
The sound is the same
Once you have finished with Nvidia drivers, you may want to try using alsamixer as another way to view your sound settings.
In terminal type:
alsamixer
then hit F6 to confirm which sound card.
then hit F5 to display All sound channels.
Have a look for any output channels marked [MM] i.e. muted.
Use arrow keys to move to a muted channel and hot "M" to unmute.
Also increase the volume level of the channel.
You could also have a play around with "Auto-Mute" and "Loopback mode" channel settings if you can see those.
You may wish to take a screenshot of your alsamixer and post it here.
To save a good alsamixer setting use:
sudo alsactl store
i don't see output device to unmute
Try default:1 or 2 and see.
Speakers look OK there, just headphone [Muted]. You could try unmuting that also in case it helps.
Have you tried setting "Auto-mut" to Disabled.
Also. F5 should display "All" sound channels, not just outputs.
Did you do that?
i tried automuted disabled and enable, nothing change
Cant read cropped bottom of screen.
sorry
Has anything helped?
Sound issues can be difficult and frustrating to diagnose and fix. Often a lot of trial and error.
Nothing chaged, i have to decrease something?
If sound is distorted, try decreasing sliders out of red zone.
Sound is bad and low, try to listen the audio i sent yesterday
Bass speaker Is lock to zero, maybe it doesn't work with zorin
I suspect pulse audio or alsamixer tools will not get you good sound.
I just did some websearches using: "Realtek ALC285 bad sound ubuntu 22.04" as searchterm.
Others are reporting problems with Realtek ALC285 e.g. sound - Low volume in Realtek ALC 285 Ubuntu 22.04 for HP laptop - Ask Ubuntu
I wonder if a different kernel may help.
EDIT: This may be relevant: https://www.reddit.com/r/ZephyrusG14/comments/1clkle1/any_solutions_for_the_sound_issue_on_g14_2024/
which has link to this:
https://www.phoronix.com/news/Linux-6.10-ASUS-ROG-2024-13X
So i have to switch kernel? I don't have idea of how to switch kernel
