Hello. In Zorin Core I can’t find option to customize taskbar. Before I installed Zorin Core, I tried Zorin Lite and I succeeded to customize taskbar (to arrange stuffs and add features like workspaces and other panels).
What should I do in Zorin Core to costumize taskbar?
David, Zorin Lite uses the XFCE desktop whereas Core uses the Gnome Desktop. While the XFCE4-panel (taskbar) is easily configurable, the Gnome version is a lot less intuitive.
You will probably want gnome tweak tool if you have not installed it already.
I am sure there are other ways through gconf, as well. I stopped using GNome due to such changes to the desktop environment that I found counterproductive and stick with Zorin Lite.
Your other options are to look at other Desktop Environments, LXQt, Enlightenment, Cinnamon. I’d love to get CairoDock DE working but it just won’t work with the latest distro’s based on 18.04.
Wow, thats another issue im dealing with, how to add apps on taskbar, i even isntalled this Extention thing and still cant figure out how to add apps ....hate to be so dissapointed ....
Have you tested Zorin Pro LITE on that MacPro?
I think you may find the settings arrangements and configuration of Lite to be a lot easier.
The Gnome desktop (What comes with Zorin Pro or Core) does take... some getting used to where configuration is concerned...
