Dell XPS Plus (9320) No Network - No Sound
I have a brand new Dell XPS 13 Plus (9320) delivered with Windows 11 preinstalled.
I have had no end of problems trying to install Zorin Os 16.2. The aim was to install Zorin alongside Windows Dual boot, 800GB Zorin, The remaining (200GB) Windows.
Right from the off, when booting Zorin form the USB drive, there was no access to WiFi an no Sound (Only sound device reported "Dummy Output"). Also, Fractional scaling for the display was presented as an option but would only work at 100% and 200%.
Many items I read point to the configuration of the BIOS (excuse my ignorance on matters Windows) But these are the options that I am now currently using (and I have tried cold booting)
Boot Configurtion
  • Secure Boot: Off
  • Enable Microsoft EFICA: On
  • Secure Boot Mode: Audit Mode
Integrated Devices
  • Enable Camera: On
  • Enable Audio: On
  • Enable Microphone: On
  • Enable Internal Speaker: On
Storage
  • ATA/NVMe operation: AHCI/NVMe
Connection
  • WLAN: On
  • Bluetooth: On
  • Enable UEFI Network Stack: Enabled
Pre-Boot Behavior
  • Fastboot: Thorough
  • Extend BIOS POST Time: 5 seconds
At one point I used the Storage RAID option and that resulted in an unbootable system and I had to call DELL to get me out of trouble!
The BIOS configuration above now at leasts will boot Zorin but - no Wifi, No Sound, Only 100%and 200% display scaling.
Booting from Windows 11 there is no problem with Sound, WiFi or fractional scaling.
When booted from Zorin, If I connect my phone via USB and enable USB tethering on the mobile 'phone I can also access the internet.
I am at a loss!!!
Can anyone suggest how I may get WiFi and Sound and hopefully fractional scaling to work?
Dell Computer Spec:
System Service Tags: 8DF1TV3
Windows 11 Home, English, Dutch, French, German, Italian 1 SR
Intel(R) Iris(R) Xe Graphics 1 SR
32GB, LPDDR5, 6000 MHz, integrated, dual channel 1 SR
1TB M.2 PCIe NVMe Solid State Drive 1 SR
13.4 OLED 3.5K (3456x2160) InfinityEdge Touch Anti-Reflective 400-Nit Display
You probably (possible) need a more up-to-date kernel is my guess as your computer is brand new. Possible a kernel 6.x.x
Lets see if it can see the devices:
sudo apt install inxi
inxi -A
inxi -N
Results:
michael@Slappy:~$ inxi -A
Audio: Device-1: Intel driver: intel-ipu6
Device-2: Intel driver: snd_hda_intel
Sound Server: ALSA v: k5.15.0-75-generic
michael@Slappy:~$ inxi -N
Network: Device-1: Intel driver: N/A
Hm... not good
Lets dig a little deeper on the net card
sudo lshw -C network
regarding audio, try experiment with alsamixer
alsamixer
@Storm
Firstly, many thanks for taking an interest and offering help.
michael@Slappy:~$ sudo lshw -C network
  *-network UNCLAIMED
       description: Network controller
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 14.3
       bus info: pci@0000:00:14.3
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix cap_list
       configuration: latency=0
       resources: iomemory:600-5ff memory:603e1e4000-603e1e7fff
  *-network
       physical id: 3
       bus info: usb@3:3
       logical name: usb0
       serial: 92:2b:ce:4e:38:cd
       capabilities: ethernet physical
       configuration: autonegotiation=off broadcast=yes driver=rndis_host driverversion=5.15.0-75-generic duplex=half firmware=RNDIS device ip=192.168.29.222 link=yes multicast=yes port=twisted pair
The above was collected whilst networking was enabled over USB (tethering)
Regarding audio:
alsamixer reports:
Card: HDA Intel PCH
with the message: This sound device does not have any controls.
Edited to add I paired a Bluetooth speaker with Zorin Dell XPS Plus laptop successfully but it was still not listed as a sound device.
The drivers/firmware need to be updated. The easiest way to do that is install a newer version of the kernel.
Storm is right. You can find a tutorial in the tutorial and guides category of this forum.
Ensure you backup any data you don't want to lose (i know it's a new pc, but that is something you normally do during installation, import what's important to you) and your home folder.
Update the kernel by the guide and reboot.
If you search this forum for, how to upgrade kernel, it should be the first link. The guide specifically mentions zorin 16.2 kernel.
Thanks - I will try that now and report back.
Using this guide: How to upgrade Zorin 16.2 to a newer kernel
At the step:
> sudo add-apt-repository --remove "deb http://ca.archive.ubuntu.com/ubuntu jammy main"
> sudo apt install libssl3
I get lots of errors:
Get:1 Index of /ubuntu jammy/main amd64 locales all 2.35-0ubuntu3 [4,249 kB]
Err:2 http://ca.archive.ubuntu.com/ubuntu jammy/main amd64 libc6 amd64 2.35-0ubuntu3
Cannot initiate the connection to ca.archive.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Cannot initiate the connection to ca.archive.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Could not connect to ca.archive.ubuntu.com:80 (91.189.91.38), connection timed out Could not connect to ca.archive.ubuntu.com:80 (91.189.91.39), connection timed out [IP: 91.189.91.39 80]
My network (tethered through USB to phone is working fine (posting this response through that connection).
Any advice?
I recommend using the TuxInvader LTS Mainline, instead.
The steps are:
sudo add-apt-repository ppa:tuxinvader/lts-mainline
sudo apt update && sudo apt install linux-generic-6.02
That should install the 6.2 kernel. Reboot and test.
Check kernel after reboot with uname -r
Many thanks. I found this solves the WiFi issue and now many more screen resolutions are listed (though fractional scaling does not work - that's no big issue for me). However, there is still no sound.
The only Sound Output Device listed is "Dummy Output"
Any suggestions?
What is the terminal output of
sudo lshw -C multimedia
michael@Slappy:~$ sudo lshw -C multimedia
[sudo] password for michael:
  *-multimedia:0 UNCLAIMED
       description: Multimedia controller
       physical id: 5
       bus info: pci@0000:00:05.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress pm cap_list
       resources: iomemory:600-5ff memory:603c000000-603cffffff
  *-multimedia:1
       description: Multimedia audio controller
       physical id: 1f.3
       bus info: pci@0000:00:1f.3
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list
       configuration: driver=sof-audio-pci-intel-tgl latency=64
       resources: iomemory:600-5ff iomemory:600-5ff irq:16 memory:603e1e0000-603e1e3fff memory:603e000000-603e0fffff
michael@Slappy:~$
Run
sudo apt full-upgrade
Reboot and test. If still no sound, in terminal run
echo "options snd-hda-intel probe_mask=1" | sudo tee -a /etc/modprobe.d/xps.conf
Source: HdaIntelSoundHowto - Community Help Wiki
Reboot - test...
If still now good, try:
echo "options snd-hda-intel probe_mask=254" | sudo tee -a /etc/modprobe.d/xps.conf
Did a search on "dummy output" here on the forum and found this re Dell which may (or may not) help.
The issue of no sound with "dummy output" is a regular occurance on the forum, so a search is a good start point.
Also as previously mentioned, from terminal run alsamixer hit F6 to see detected sound cards. Post a screenshot.
On reboot, I get to a completely black screen with a white text prompt to login in
I can log in under my username and password and I get a shell prompt.
I seem to have entirely lost the window manager.
I am now in a complete mess!
If I choose Zorin Advanced Options during the boot sequence it looks like I have a choice of several Zorin versions. None seem to complete booting into a window manager. I never get past a black screen, white text, login prompt.
Suggestions?
With an installation Windows and Zorin
You first have to disable the Security Boot
In your BIOS Menu
Then start the USB stick
Regards
Security Boot was disabled (see original post) from the beginning.
Have you also stored this in the BIOS
If not, it is switched on again
Yes, just checked, Secure Boot remains disabled in BIOS
Okay
and Lecasy support in your BIOS
Has it been enabled?
So
Security Boot -Disable
lecasy support-enable
