Where was that number coming from?
Please give me the source.
I just caution you that Statistical genetics is a part on my daily job. It is not that easy to convince me with numbers and figures in absence of a solid evidence.
mark@mark-main-PC:~$ sudo modprobe -r rtl8192ee && sudo modprobe rtl8193ee
[sudo] password for mark:
modprobe: FATAL: Module rtl8193ee not found in directory /lib/modules/5.11.0-27-generic
The kernel lacks the driver.
-sigh-
I wonder if the 5.8 kernel would be better... I am reasonably sure it has the driver. I know 5.4 does...
What is the scale of your sampling?
Considering the number of products circulating around the planet, it is next to impossible for an individual to make such assumption from the limited number of samples one can get their hands on.
You have to be very careful for underestimating a limit of one's observation capability. If you extend such idea on people, this will quickly going to the "stereo typing".
Just let me know what to do lol
The big problem is that... It should work, but it doesn't. Your hardware is compatible.
Another proof that the "latest and newest" is not necessary a good kernel to use.
@Aravisian is trying to help OP to roll back the kernel to get the missing driver back.
Stay tuned
I actually doubt it will work because the kernal should have the driver. Still worth a shot tho
Yes, it "should" but in reality it doesn't.
(This is called a reality of life).
Sometime kernel does drop a support for the older hardware intentionally or accidentally.
The 5.11 kernel is not LTS. It is the Hirsute Hippo testing kernel.
Back to the machine or OS that has internet... Copy these links and then use them there:
Save each file on your USB and transfer them to Zorin OS.
Save them as they are in your Downloads Folder.
Open a terminal and Change Directory (CD) to that folder
cd ~/Downloads
Now run the install command to install all the packages at once:
sudo dpkg -i *.deb
Once done... reboot and test...
done all that, rebooted and still the same. wired network still tries to connect but wont and i can't see the wifi tab anymore
What is the terminal output of
uname -a
mark@mark-main-PC:~$ uname -a
Linux mark-main-PC 5.11.0-27-generic #29~20.04.1-Ubuntu SMP Wed Aug 11 15:58:17 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Looks fine to me
You are still on the 5.11 kernel.
Can you hold or Tap the left shift key at boot to pull up Advanced Options for Zorin and from there, select the 5.8 kernel.
Please see here:
you guys are trying to downgrade the kernal
Linux mark-main-PC 5.8.0-050800-generic #202008022230 SMP Sun Aug 2 22:33:21 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
I was given 2 options, 5.8 generic or 5.8 recovery mode. i fired it up in generic and it is still the same
@Aravisian Did he do it right, I think he did? @Warrioruw Can you show a photo of your PCIE Wi-Fi card?
