Working with geary I tried to delete some messages and nothing happened. Trying a cleanup the db files was marked read-only. I tried a M$ ploy and restarted, and there I was in the login loop. Using the fixes in Swarfendor437’s invaluable manual I finally managed to clean up and all’s well. I tried so many solutions I’ve forgotten which one worked. Some idiot questions:
In some of the commands, what do I put in place of [code]?
2.How do I boot into advanced recovery mode? I’ve tried ctl-alt-F3 but to no avail.
Hold the left shift key down whilst you power on, also try stabbing the left shift key during boot and you “should” get GRUB - only then can you access the advanced menu.
Have you tried this?:
Thanks for the info. I got into the (an?) advanced page by hitting ctl-alt-F3 once the display stopped to the login page. If I get into GRUB, what do I do next, please? (Told you I am a total newbie!)
