It’s worth a shot. I’d try it. I do not have enough knowledge to really know.
I’ll try it out to see if it will have some sort of effect or not. Thanks again for your help!
Fwiw, since you’ve already tried Zorin, can’t hurt to try other distros to see if they take care of your problem. Should be a lot faster than reinstalling Windows.
Not a bad idea actually, will do, thanks!
did anything work for you ? I am having a similar problem.
Marked solution. 25
A post was split to a new topic: Cannot control Airplane mode or bluetooth from settings
A post was split to a new topic: Wifi Airplane Mode activates itself
