I installed Zorin OS 16 a few weeks ago dual booting with Windows 11. I don't use Windows anymore but I need to keep it for now.
Yesterday I tried to install Ubuntu Budgie on to a USB stick (not writing the iso on it but actually install the system on to the USB stick).
Ubuntu automatically installs the boot loader in the advanced options for installation. So I chose the USB stick for everything.
When I restarten I had all my systems in the Ubuntu boot menu and startet Ubuntu.
BUT after a new restart I got the GNU Grub Command Screen (not Grub rescue, just the "normal"GNU Grub 2.04).
If I type "exit" Windows will start (at least most of the time).
I managed to get the Zorin boot menu back (with windows to choose as well) but it seems just temporary. Every time I restart I am back in the GNU Grub Command Screen.
Then I do this again:
set boot=(hd0,gpt7)
set prefix=(hd0,gpt7)/boot/grub
insmod normal
normal
This brings me back to the dual boot menu of Zorin 16 (hd0,gpt7 is where Zorin is installed)
But how do I get it back permanently!?
Thanks in advance and hello to everyone - I am new here
Okay, so I did the Grub Customizer thing. But the only thing it did was changing my boot loader screen (to the worse wehre I choose what to start. It is no small in the top left Corner and before it was the one from the Zorin installation.
But it didn't change anything else. I still land in this screen (see Picture)
You can make a bootable USB key like any other Linux installer. Boot from this USB key and follow the instruction. I suggest you to read the procedure in advance.
I think this from AZorin How to fix the boot menu if it disappears
is the same but I didn't try it yet cause I have to restart and the the Grub command thing again to be able to access the BIOS and be able to boot from a usb stick (if it works at all
I wrote the Zorin Iso on to the stick so I guess I will try this now...
Okay
After the repair computer loads into the boot menu again with all 4 Options I had before.
But the Menu still doesn't look like the one I got after the initial install of Zorin os 16. Now it looks like the Ubuntu boot menu.
I am not sure if the GRUB Customisation caused this (although I didn't change anything but before that the menu was the Zorin original and I want it back it is way prettier!!
Strange thing is that I am using Grub customizer on my 10 years old Acer Aspire dual-booting Windows 11 (yes, it is possible) and Zorin 15,3 and the boot screen looks like the bottom image you have posted.
Oh, wait, where your Windows 11 went?
I do not see it in the list.
Be earnest with you, I've never paid much attention to how the boot screen looks like. I will ask other volunteers who might have a better idea. @zabadabadoo@Storm
Me either. I was always good with the Ubuntu Boot screen but now that I got the Zorin one it looks so .... hmm ugly
and it is just super small and the zorin os theme was just so clear and clean and easy readable
It seems that with the try of the Ubuntu Budgie install on the usb stick it overwrote the Zorin 16 boot menu to the Ubuntu one. And now I am stuck with it.
