sudo apt remove --purge xubuntu-desktop
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt remove --purge xubuntu-desktop
[sudo] password for mike:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
xubuntu-core : Depends: xubuntu-default-settings but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Run
sudo apt --fix-broken install
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt --fix-broken install
Correcting dependencies... Done
chromium-codecs-ffmpeg-extra gstreamer1.0-vaapi heif-gdk-pixbuf
0 upgraded, 1 newly installed, 0 to remove and 4 not upgraded.
2 not fully installed or removed.
Need to get 0 B/40.3 kB of archives.
After this operation, 266 kB of additional disk space will be used.
(Reading database ... 332754 files and directories currently installed.)
Preparing to unpack .../xubuntu-default-settings_20.04.4_all.deb ...
Unpacking xubuntu-default-settings (20.04.4) ...
dpkg: error processing archive /var/cache/apt/archives/xubuntu-default-settings_20.04.4_all.deb (--unpack):
trying to overwrite '/etc/skel/.config/libreoffice/4/user/registrymodifications.xcu', which is also in package zorin-os-default-settin
gs 16.3
sudo apt remove --purge xubuntu-desktop xubuntu-default-settings xubuntu-core
Removing xubuntu-desktop (2.233) ...
Removing xubuntu-core (2.233) ...
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt remove --purge xubuntu-desktop xubuntu-default-settings xubuntu-core
Package 'xubuntu-default-settings' is not installed, so not removed
blueman catfish chromium-codecs-ffmpeg-extra dmz-cursor-theme doc-base fonts-noto-hinted fonts-symbola gigolo
gir1.2-appindicator3-0.1 gir1.2-cheese-3.0 gstreamer1.0-nice gstreamer1.0-vaapi gucharmap hddtemp heif-gdk-pixbuf inxi libexo-1-0
libfarstream-0.2-5 libgadu3 libgtksourceview-3.0-1 libgtksourceview-3.0-common libgtkspell0 libgucharmap-2-90-7 libmeanwhile1
libotr5 libprotobuf-c1 libpurple-bin libpurple0 libunique-1.0-0 libuuid-perl libyaml-tiny-perl libzephyr4 mate-calc
mate-calc-common menulibre mousepad mugshot numix-gtk-theme onboard onboard-common onboard-data parole pastebinit pidgin
pidgin-data pidgin-otr python3-xcffib ristretto sgt-launcher sgt-puzzles shimmer-themes thunderbird tree whoopsie xfburn
xfce4-cpugraph-plugin xfce4-dict xfce4-mailwatch-plugin xfce4-netload-plugin xfce4-notes xfce4-notes-plugin xfce4-panel-profiles
xfce4-places-plugin xfce4-systemload-plugin xfce4-taskmanager xfce4-verve-plugin xfce4-weather-plugin xfce4-whiskermenu-plugin
xfce4-xkb-plugin xfpanel-switch xubuntu-artwork xubuntu-community-wallpapers xubuntu-community-wallpapers-focal xubuntu-docs
xubuntu-wallpapers
The following packages will be REMOVED:
xubuntu-core* xubuntu-desktop*
0 upgraded, 0 newly installed, 2 to remove and 4 not upgraded.
After this operation, 59.4 kB disk space will be freed.
sudo apt install --reinstall xfce4 xfce4-goodies
Once done;
Please download this keyboard-shortcuts xml file and move it to ~/.config/xfce4/xconf/xfce-perchannel-xml
Log out and in, then back into Window Manager > Keyboard and check the shortcuts...
OK I'll pick this up tomorrow as we just had company come over .... thank you very much for your patience .... see ya tomorrow ....
WHOA
Do not shut down the computer until you have run the command above!
Follow Aravisian instructions now, you want to run that command before you shutdown, because you know what happens if you shutdown without running that command?
You cause a parabolic destabilization of the quantum universe. It could send you back to 1955, I know scary!
Yoy ain't gonna believe what just happened .... when I went to close out window keyboard I looked at the window left and window right and just hit edit and typed in then hit the super key + the left arrow and it came up Super+left arrow and then I did the same thing with the right arrow .... and guess what .... I got the super + arrow keys to work .... not sure what will happen when I open up tomorrow but right now they are working ....
.... unbelievable .... thank you again for all your help ....
Frog- see above or you will be rebuilding your desktop tomorrow.
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt install --reinstall xfce4 xfce4-goodies
blueman catfish chromium-codecs-ffmpeg-extra dmz-cursor-theme doc-base fonts-noto-hinted fonts-symbola gir1.2-appindicator3-0.1
gstreamer1.0-nice gstreamer1.0-vaapi gucharmap heif-gdk-pixbuf inxi libfarstream-0.2-5 libgadu3 libgtkspell0 libgucharmap-2-90-7
libmeanwhile1 libotr5 libprotobuf-c1 libpurple-bin libpurple0 libuuid-perl libyaml-tiny-perl libzephyr4 mate-calc mate-calc-common
menulibre numix-gtk-theme onboard onboard-common onboard-data pastebinit pidgin pidgin-data pidgin-otr python3-xcffib sgt-launcher
sgt-puzzles shimmer-themes thunderbird tree whoopsie xfce4-panel-profiles xfpanel-switch xubuntu-artwork
xubuntu-community-wallpapers xubuntu-community-wallpapers-focal xubuntu-docs xubuntu-wallpapers
libqrencode4 xfce4-battery-plugin xfce4-clipman xfce4-clipman-plugin xfce4-cpufreq-plugin xfce4-datetime-plugin
xfce4-diskperf-plugin xfce4-fsguard-plugin xfce4-genmon-plugin xfce4-sensors-plugin xfce4-smartbookmark-plugin xfce4-timer-plugin
xfce4-wavelan-plugin
Suggested packages:
xfce4-mpc-plugin xfce4-radio-plugin xsensors
xfce4-diskperf-plugin xfce4-fsguard-plugin xfce4-genmon-plugin xfce4-goodies xfce4-sensors-plugin xfce4-smartbookmark-plugin
xfce4-timer-plugin xfce4-wavelan-plugin
0 upgraded, 14 newly installed, 1 reinstalled, 0 to remove and 4 not upgraded.
Need to get 712 kB of archives.
After this operation, 4,960 kB of additional disk space will be used.
Get:1 Index of /ubuntu focal/universe amd64 libqrencode4 amd64 4.0.2-2 [23.6 kB]
Get:2 Index of /ubuntu focal/universe amd64 xfce4 all 4.14 [4,980 B]
Get:3 Index of /ubuntu focal/universe amd64 xfce4-battery-plugin amd64 1.1.3-1 [89.6 kB]
Get:4 Index of /ubuntu focal/universe amd64 xfce4-clipman amd64 2:1.4.4-1 [123 kB]
Get:5 Index of /ubuntu focal/universe amd64 xfce4-clipman-plugin amd64 2:1.4.4-1 [23.6 kB]
Get:6 Index of /ubuntu focal/universe amd64 xfce4-cpufreq-plugin amd64 1.2.1-1 [54.9 kB]
Get:7 Index of /ubuntu focal/universe amd64 xfce4-datetime-plugin amd64 0.8.0-1 [31.2 kB]
Get:8 Index of /ubuntu focal/universe amd64 xfce4-diskperf-plugin amd64 2.6.2-1 [48.6 kB]
Get:9 Index of /ubuntu focal/universe amd64 xfce4-fsguard-plugin amd64 1.1.1-1 [57.5 kB]
Get:10 Index of /ubuntu focal/universe amd64 xfce4-genmon-plugin amd64 4.0.2-1 [31.9 kB]
Get:11 Index of /ubuntu focal/universe amd64 xfce4-sensors-plugin amd64 1.3.0-2build1 [118 kB]
Get:12 Index of /ubuntu focal/universe amd64 xfce4-smartbookmark-plugin amd64 0.5.1-1 [20.9 kB]
Get:13 Index of /ubuntu focal/universe amd64 xfce4-timer-plugin amd64 1.7.0-1 [49.7 kB]
Get:14 Index of /ubuntu focal/universe amd64 xfce4-wavelan-plugin amd64 0.6.1-1 [30.7 kB]
Get:15 Index of /ubuntu focal/universe amd64 xfce4-goodies amd64 4.14.0 [3,868 B]
Fetched 712 kB in 5s (150 kB/s)
Selecting previously unselected package libqrencode4:amd64.
(Reading database ... 332748 files and directories currently installed.)
Preparing to unpack .../00-libqrencode4_4.0.2-2_amd64.deb ...
Unpacking libqrencode4:amd64 (4.0.2-2) ...
Preparing to unpack .../01-xfce4_4.14_all.deb ...
Unpacking xfce4 (4.14) over (4.14) ...
Selecting previously unselected package xfce4-battery-plugin.
Preparing to unpack .../02-xfce4-battery-plugin_1.1.3-1_amd64.deb ...
Unpacking xfce4-battery-plugin (1.1.3-1) ...
Selecting previously unselected package xfce4-clipman.
Preparing to unpack .../03-xfce4-clipman_2%3a1.4.4-1_amd64.deb ...
Unpacking xfce4-clipman (2:1.4.4-1) ...
Selecting previously unselected package xfce4-clipman-plugin.
Preparing to unpack .../04-xfce4-clipman-plugin_2%3a1.4.4-1_amd64.deb ...
Unpacking xfce4-clipman-plugin (2:1.4.4-1) ...
Selecting previously unselected package xfce4-cpufreq-plugin.
Preparing to unpack .../05-xfce4-cpufreq-plugin_1.2.1-1_amd64.deb ...
Unpacking xfce4-cpufreq-plugin (1.2.1-1) ...
Selecting previously unselected package xfce4-datetime-plugin.
Preparing to unpack .../06-xfce4-datetime-plugin_0.8.0-1_amd64.deb ...
Unpacking xfce4-datetime-plugin (0.8.0-1) ...
Selecting previously unselected package xfce4-diskperf-plugin.
Preparing to unpack .../07-xfce4-diskperf-plugin_2.6.2-1_amd64.deb ...
Unpacking xfce4-diskperf-plugin (2.6.2-1) ...
Selecting previously unselected package xfce4-fsguard-plugin:amd64.
Preparing to unpack .../08-xfce4-fsguard-plugin_1.1.1-1_amd64.deb ...
Unpacking xfce4-fsguard-plugin:amd64 (1.1.1-1) ...
Selecting previously unselected package xfce4-genmon-plugin:amd64.
Preparing to unpack .../09-xfce4-genmon-plugin_4.0.2-1_amd64.deb ...
Unpacking xfce4-genmon-plugin:amd64 (4.0.2-1) ...
Selecting previously unselected package xfce4-sensors-plugin.
Preparing to unpack .../10-xfce4-sensors-plugin_1.3.0-2build1_amd64.deb ...
Unpacking xfce4-sensors-plugin (1.3.0-2build1) ...
Selecting previously unselected package xfce4-smartbookmark-plugin.
Preparing to unpack .../11-xfce4-smartbookmark-plugin_0.5.1-1_amd64.deb ...
Unpacking xfce4-smartbookmark-plugin (0.5.1-1) ...
Selecting previously unselected package xfce4-timer-plugin.
Preparing to unpack .../12-xfce4-timer-plugin_1.7.0-1_amd64.deb ...
Unpacking xfce4-timer-plugin (1.7.0-1) ...
Selecting previously unselected package xfce4-wavelan-plugin.
Preparing to unpack .../13-xfce4-wavelan-plugin_0.6.1-1_amd64.deb ...
Unpacking xfce4-wavelan-plugin (0.6.1-1) ...
Selecting previously unselected package xfce4-goodies.
Preparing to unpack .../14-xfce4-goodies_4.14.0_amd64.deb ...
Unpacking xfce4-goodies (4.14.0) ...
Setting up xfce4-smartbookmark-plugin (0.5.1-1) ...
Setting up libqrencode4:amd64 (4.0.2-2) ...
Setting up xfce4-sensors-plugin (1.3.0-2build1) ...
Setting up xfce4 (4.14) ...
Setting up xfce4-wavelan-plugin (0.6.1-1) ...
Setting up xfce4-timer-plugin (1.7.0-1) ...
Setting up xfce4-battery-plugin (1.1.3-1) ...
Setting up xfce4-datetime-plugin (0.8.0-1) ...
Setting up xfce4-diskperf-plugin (2.6.2-1) ...
Setting up xfce4-genmon-plugin:amd64 (4.0.2-1) ...
Setting up xfce4-clipman (2:1.4.4-1) ...
Setting up xfce4-cpufreq-plugin (1.2.1-1) ...
Setting up xfce4-fsguard-plugin:amd64 (1.1.1-1) ...
Setting up xfce4-clipman-plugin (2:1.4.4-1) ...
Setting up xfce4-goodies (4.14.0) ...
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Is that what you meant ?????
Thanks, your D.E. is safe for now.
Oh thank God, I was sweating, I thought we were going to lose you into 1955, we'd meet again today and you'd be 90 years old, and saying, I should have listen to you guys when you told me to run that command.
My god my heart just about stopped .... my company got a good laugh when the color drained from my face ... but they don't know about these sort of things ...
OK all I am signing off .... sure glad I ain't a drinking man ....
If you were a drinking man, your fingers and toes would be drunk, lord knows where the code in terminal would end up. Good save!
No... it's just that in trying to correct the problem, we did some Removals of desktop components that we needed to be sure were back in place before stopping the process is all.
