Okay, so I will reinstall and see if the error happens again.
RIGHT now, I am downloading the ISO
When you have downloaded the .iso, check the SHA256 checksum matches the Zorin website published value, before creating your USB.
Ref: Methods of downloading Zorin OS - #8 by zabadabadoo
Hello!
I am dual booting, your way seems not suitable for dual booting.
Here is a screenshot for available dirs.
nvme0n1:
sda is my usb.
i will setup my installation as the followeing:
I followed this guide Manually Partition the Drive to Install Zorin OS - Zorin Help
I will continue with this install after 10 min starting from now, i will execute at 17:46
OK, so you use 265 Gb for Zorin. You could therefore create an 80 Gb partition for '/', and the rest format for '/home'. The advantage of doing this is that if your system goes west your data remains intact and you only need to reinstall to '/'.
After reinstalling, my problem is solved except one.
I'm not sure if my previous installation is corrupted or not, but
If this problem occurred again, I might repost here or create a new topic.
The one problem that wasn't solved is:
Root permission popup in lock screen when there is no connection to Wi-Fi or Ethernet.
Should I create a new topic for this issue?
Also, thank you everyone for helping me!
Good idea.
