Hello, my microphone worked perfectly in windows, but now it has a very strong sound and it sounds bad, all that without speaking.
Any advice to fix the problem?
This has come up before and I, for one, have had very little luck in helping:
If you scroll to the Last answer provided "In 2020," and try the steps outlined there; it may be a good starting point.
Please be sure to also check that your Mic Volume is not set to higher than 40% in the pavucontrol settings:
sudo apt install pavucontrol
pavucontrol
If no luck there, please update this thread. Pulseaudio and its modules are... interesting... with sound and mic issues. It may take a lot of troubleshooting.
EDIT: This thread makes a point about how OBS does not use an…
Hello, I'm new to Linux and I would like to see if anyone can help me out with a problem.
Recently, I moved from Windows 10 to Zorin OS 15 Core and I'm loving it, but my internal mic and camera aren't functioning properly. The mic is noisy and muffled. When I connect an external mic, the noise is gone but the sound is still muffled/low. The camera is too dark. I can change its settings in the apps Cheese and Qtcam, but when I do videocalls the image gets darker again. I haven't tried using an e…
