Nebula Them Suite for Gnome & Budgie DE. It will contain icon theme, GTK theme, Gnome-shell theme and plank theme. It's highly recommendable to use with Plank.
One strange thing - I used your shade of green - as a base for my icons and also added the symbolic links (in the folder places) so the icons on main menu and the left side in Nautilus would show.
They do work for my icons but not for yours. Tried to add the icons with link to your nebula places folder but still they don't show. Don't know why.
it works like this (for Gnome). In folder places/scalable;
icon present in folder -> icon added by me:
-folder-documents.svg -> -folder-documents-symbolic.svg
You want to place the Symbolic icons in the 16x16 folder, not the scalable folder. Otherwise, you can run into situations where they appear quite... large...
Please check the index.theme file for the theme that you are using and ensure that the directory is listed.
Something like:
I even changed the "MinSize" to 16 although the svg files ar 24x24px. But like I said I use his shade of Green (index file) and have the symbolic files - only - present in the folder scalable, and they all show as symbolic icons.
