While I successfully disabled the service, so its not showing in the analyze blame command but disk checking is still happening during boot. This has led to a delay despite my efforts.
I aim to reduce the boot time on Zorin OS. The specific issue is the disk checking process, which is taking much time during boot. Ideally, I'd like to bring this down to around 2-3 seconds, similar to the boot time on my trimmed down Debian system.
Wow, thanks for this info.
I do encounter some random behavior on my several devices related to booting time on Zorin OS (dual boot mode), some device had longer boot time about 10~20 second (although it's have an identical device hardware).
I'll try to disable Windows Fast Startup now.
From what I've read, Windows Fast Startup is actually a form of hibernation. Which means when you "shut down" Windows, it isn't really turned off, it keeps a grip on the hardware and thus Fast Startup can cause serious problems for other OSes on the same machine. It's recommended to turn off Fast Start before installing another OS.
