Hello there! I recently dual booted ZorinOS 16 Core(disabling Secure Boot and Fast Boot) with my Windows 11, but later learnt bluetooth wasn't getting enabled for some reason
I am just going to assume you tried flipping on the toggle on the upper right hand side of the Bluetooth menu, and it was not turning on Bluetooth correct.
Initially, I would have suspected that you didn't have the driver installed for your wireless adapter. But seeing your additional drivers APP, tells me that you do have the drivers installed.
Another solution is to avoid the Bluetooth functionality that Zorin OS 16 comes with, and upgrading to Blueman. Go to the software center and search for "Bluetooth Manager." You will know you have the right one found, as its by the Blueman group.
Install that, then after Blueman is installed, restart the computer. Then click on the logo at the bottom left of your screen, and type in "Blueman." If Blueman finds your Bluetooth adapter, it will ask you to turn it on.
Once your Bluetooth adapter is on, it should be functioning normally. One last thing, I am sure you've already checked this, but usually most notebook computers have the ability to switch the wireless adapter on/off on the hardware level via the FN key shortcut.
So just double check that as well, to make sure its not off. If everything above fails first, then check that. OK, hope this helps!
Keep in mind that sometimes hardware in computers are made by the manufacturer, to only support WINDOWS. This means no matter what you do, you will never get it working in linux. This might be the case for your unit.
As we already know that you do have a bluetooth adapter, and while that message from bluemean usually means you don't have one, we know you do have an adapter, cause you were using it on Windows.
There is an easier way around this issue. Go to whatever your country uses for an online store, they seem to differ global wide. We here use Amazon. Pickout a well rated bluetooth adapter that supports linux. It will be an USB dongle.
Then all you gotta do is plug that sucker into an available USB port, and I can 99% gurrantee you, that Blueman is going to pick that puppy up and say, do you wanna turn it on? And your going to say, heck yes I do, click!
Open your Downloads folder, right click the Linux_BT_USB...tar.gz file and select extract here.
Double click into the newly created Linux_BT_USB... directory. Right click an open area and select "Open in terminal."
If the menu does not have that option for Gnome's file manager, then open a terminal with keyboard shortcut ctrl+alt+t
Paste into it: cd ~/Downloads/Linux_BT_USB_v3.10_20170802_8821CU_BTCOEX_20170516-1616
Let me know if you get an error that says includes a BUILD_EXCLUSIVE directive which does not match this kernel/arch. This indicates that it should not be built. Skipped.
