Hello,
I freshly installed ZorinOS 16.2 with kernel Linux 5.15.0-67-generic on a:
Exone D3400-B1 (Fujitsu Motherboard) with an Intel H110 chipset and a LGA 1151 socket.
The sound chip is an
00:1f.3 Audio device: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller (rev 31)
according to lspci. Additionally there is a NVIDIA GTX 950 installed.
01:00.1 Audio device: NVIDIA Corporation GM206 High Definition Audio Controller (rev a1) (which seems to be deactivated according to pavucontrol)
The OS seems to use ALC671 / snd_hda_intel
dmesg | grep -C1 -E 'ALSA|HDA|sof|HDMI|snd[_-]|sound|hda.codec|hda.intel'
shows:
[ 0.161602] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.161602] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.161602] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.298555] PCI: CLS 0 bytes, default 64
[ 0.298611] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.298612] software IO TLB: mapped [mem 0x00000000c490c000-0x00000000c890c000] (64MB)
[ 0.298629] Trying to unpack rootfs image as initramfs...
[ 4.145110] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 4.158123] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 4.158127] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 4.166820] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 4.168152] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 4.185439] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[ 4.185483] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[ 4.185523] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[ 4.185562] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[ 4.185606] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[ 4.185642] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[ 4.185679] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[ 4.210327] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC671: line_outs=1 (0x21/0x0/0x0/0x0/0x0) type:line
[ 4.210331] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=1 (0x17/0x0/0x0/0x0/0x0)
[ 4.210333] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x14/0x0/0x0/0x0/0x0)
[ 4.210335] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 4.210336] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.210337] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 4.210339] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 4.210340] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 4.283548] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.85.05 Sat Jan 14 00:49:50 UTC 2023
[ 4.353513] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 4.355664] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 4.355789] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 4.355862] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 4.355911] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 4.355982] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 4.359179] intel_rapl_common: Found RAPL domain package
[ 673.378377] loop0: detected capacity change from 0 to 8
[ 6402.130118] snd_hda_intel 0000:00:1f.3: Unstable LPIB (352800 >= 176400); disabling LPIB delay counting
[30008.867139] kauditd_printk_skb: 20 callbacks suppressed
aplay -l
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: PCH [HDA Intel PCH], Gerät 0: ALC671 Analog [ALC671 Analog]
Sub-Geräte: 0/1
Sub-Gerät #0: subdevice #0
Karte 1: NVidia [HDA NVidia], Gerät 3: HDMI 0 [HDMI 0]
Sub-Geräte: 1/1
Karte 1: NVidia [HDA NVidia], Gerät 7: HDMI 1 [HDMI 1]
Sub-Geräte: 1/1
Karte 1: NVidia [HDA NVidia], Gerät 8: HDMI 2 [HDMI 2]
Sub-Geräte: 1/1
Karte 1: NVidia [HDA NVidia], Gerät 9: HDMI 3 [HDMI 3]
Sub-Geräte: 1/1
Karte 1: NVidia [HDA NVidia], Gerät 10: HDMI 4 [HDMI 4]
Sub-Geräte: 1/1
Karte 1: NVidia [HDA NVidia], Gerät 11: HDMI 5 [HDMI 5]
Sub-Geräte: 1/1
Karte 1: NVidia [HDA NVidia], Gerät 12: HDMI 6 [HDMI 6]
Sub-Geräte: 1/1
If I play music and video in youtube or as single file the sound level / meter will move in pavucontrol. So there is sound. But I cannot here it. I tried different speakers too. Front and backports from the pc too.
In alsamixer the speakers seem to be muted every time I reboot. As soon as I unmute it it still plays no sound.After reboot "speakers" are muted again.
I pavucontrol it says: "Headphones plugged in" and the meters are moving while playing music.
I even tried another distro (mint) with no luck. Sound worked in windoze. ![]()
Inxi -Fz:
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
Device-2: NVIDIA GM206 High Definition Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.15.0-67-generic
cat /proc/asound/cards
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xf7220000 irq 127
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xf7080000 irq 17
ead -n 1 /proc/asound/card0/codec
Codec: Realtek ALC671
Standard in alsamixer is my "HDA intel PCH"
inxi -Axxz
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Fujitsu Solutions driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a170
Device-2: NVIDIA GM206 High Definition Audio vendor: CardExpert driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:0fba
dmesg | egrep -i "alsa|snd"
Maybe someone knows what to do?
