No, it is known for extensions bugs, because many extensions have bugs, install the same extension in nautilus 50 and you will have a bug, since I removed forlder-color from fresh new zorin 18 I never encounter any nautilus bug....
I didn't have folder-color but I had open with vscode python extension from some years ago. And nautilus was randomly freezing both in ubuntu and zorin. Anyway i removed the extension and even the nautilus extensions app but still sometimes it was getting stuck. I was mounting One/Google Drive on boot up using rclone and my solution was to use bisync command. I never had these issues with other file managers that's why I'm not a fan of nautilus. but I like your extensions to add more features to nautilus to make it like dolphin.. and I believe you work harder than the nautilus devs themselves. Thanks
