System:
Kernel: 5.11.0-40-generic x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11.0-40-generic
root=UUID=87691aae-487f-466b-98fb-10decd17dda6 ro quiet splash
vt.handoff=7
Console: tty 0 dm: GDM3 3.38.2.1 Distro: Zorin OS 16
base: Ubuntu 20.04 LTS Focal
Machine:
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
serial:
Mobo: ASUSTeK model: FX505DT v: 1.0 serial:
UEFI: American Megatrends v: FX505DT.316 date: 01/28/2021
Battery:
ID-1: BAT0 charge: 43.6 Wh condition: 43.6/48.1 Wh (91%) volts: 12.9/11.7
model: FX50442 type: Li-ion serial: status: Full
Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
serial: charge: 100% (should be ignored) rechargeable: yes
status: Discharging
CPU:
Topology: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108102 L1 cache: 384 KiB L2 cache: 2048 KiB
L3 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 33537
Speed: 1437 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1428 2: 1943 3: 1923 4: 1263 5: 1389 6: 1397 7: 1342 8: 1397
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP:
disabled, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 470.82.00 bus ID: 01:00.0 chip ID: 10de:1f91
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:15d8
Display: server: X.org 1.20.11 driver: amdgpu,ati,nvidia
unloaded: fbdev,modesetting,nouveau,vesa compositor: gnome-shell
tty: 80x24
Message: Advanced graphics data unavailable in console for root.
Audio:
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10fa
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.11.0-40-generic
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.0
chip ID: 10ec:8168
IF: enp2s0 state: down mac:
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A port: d000 bus ID: 04:00.0
chip ID: 10ec:c822
IF: wlp4s0 state: up mac:
Drives:
Local Storage: total: 476.94 GiB used: 18.46 GiB (3.9%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: rev: 004C scheme: GPT
Partition:
ID-1: / raw size: 190.96 GiB size: 186.96 GiB (97.91%)
used: 18.43 GiB (9.9%) fs: ext4 block size: 4096 B dev: /dev/nvme0n1p5
Sensors:
System Temperatures: cpu: 70.8 C mobo: N/A
Fan Speeds (RPM): cpu: 3500
Use of uninitialized value $val2 in string eq at /usr/bin/inxi line 5821.
Use of uninitialized value $val2 in split at /usr/bin/inxi line 5826.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 5828.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 5829.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 5830.
GPU: device: temp: N/A device: amdgpu temp: 70 C
Info:
Processes: 323 Uptime: 1h 19m Memory: 13.60 GiB used: 6.59 GiB (48.5%)
Init: systemd v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 9 Shell: bash
v: 5.0.17 running in: tty 0 inxi: 3.0.38
My system info for your reference.
