Hello, Zorin Community, I'm wondering if I should get Zorin OS Ultimate for my Company. We have about 120 Desktops (will expand) and 40 raspberry-pi custom tablets. We would also like to know if we could remove the Games that come with it.
Hi Derek. I would check the System Requirements for your machines, particularly Raspberry Pi's, What processor do they have?
I believe you can do a minimum, i.e. bare bones, install of Ultimate or you can choose to remove unwanted games etc after install.
Maybe you should PM @AZorin to discuss your potentail business use considering such a large number of machines.
With 140 machines, I second the opinion that sending a PM Directly to @azorin or @zorink is a great way to go. This way, you can explore your options directly with the developers. I am sure they would be happy to help.
In my post above, left click the names as highlighted with the @ sign. A popup window will appear. Upper Right of the window has a message button that you can click to send them a PM.
Another thing to think about is the type of business you have and what tools are included with Ultimate and the support and updates. You can always add and remove as needed. It's Linux. So take what you need out and keep what you want.
I am also baffled by the lack of Message button. But when I used the @ sign above on their names, it also alerts them directly to this thread and that comment.
I think it's because your account is new and you haven't unlocked that feature yet. I believe you have to hang out at the forums a little bit to unlock the ability to DM people. Alternatively, you can just email him.
Oh ok. 120 desktops. Decent size consultancy business. If you have a business that large, the cost of Ultimate is minimal...a write-off. Yet it helps a great cause. So, whether you think you need Ultimate or not for your business is irrelevant as you can always add to the lite version. Think of it as whether you want a great OS, great support, and help contribute to the success of an entity that's helping provide and support the system your business survives on.
