Sound not working despite devices detected. Lenovo M90 Pro Gen4
Mai 29 13:02:37 ElectricSunrise pipewire[20565]: mod.jackdbus-detect: Failed to receive jackdbus reply: org.freedesktop.DBus.Error.ServiceUnknown: The name org.jackaudio.service was not provided by any .service files
Mai 29 13:03:26 ElectricSunrise systemd[1969]: Stopping pipewire.service - PipeWire Multimedia Service...
Mai 29 13:03:26 ElectricSunrise systemd[1969]: Stopped pipewire.service - PipeWire Multimedia Service.
Mai 29 13:03:26 ElectricSunrise systemd[1969]: Started pipewire.service - PipeWire Multimedia Service.
Mai 29 13:03:26 ElectricSunrise pipewire[22901]: mod.jackdbus-detect: Failed to receive jackdbus reply: org.freedesktop.DBus.Error.ServiceUnknown: The name org.jackaudio.service was not provided by any .service files
Mai 29 13:03:26 ElectricSunrise pipewire[22901]: ALSA lib seq_hw.c:528:(snd_seq_hw_open) open /dev/snd/seq failed: Permission denied
Mai 29 13:03:26 ElectricSunrise pipewire[22901]: spa.alsa: open failed: Permission denied
-- Boot f37735efe76c44bd9cf20fdc2e7fcf56 --
Mai 29 13:04:29 ElectricSunrise systemd[1932]: Started pipewire.service - PipeWire Multimedia Service.
Mai 29 13:04:29 ElectricSunrise pipewire[1949]: mod.jackdbus-detect: Failed to receive jackdbus reply: org.freedesktop.DBus.Error.ServiceUnknown: The name org.jackaudio.service was not provided by any .service files
Mai 29 14:03:49 ElectricSunrise systemd[1932]: Stopping pipewire.service - PipeWire Multimedia Service...
Mai 29 14:03:49 ElectricSunrise systemd[1932]: Stopped pipewire.service - PipeWire Multimedia Service.
Mai 29 14:03:49 ElectricSunrise systemd[1932]: pipewire.service: Consumed 9.986s CPU time, 7.4M memory peak, 0B memory swap peak.
-- Boot e9ca1eb25b8945f9a6b3d10729b46ab4 --
Mai 29 14:05:25 ElectricSunrise systemd[1981]: Started pipewire.service - PipeWire Multimedia Service.
Mai 29 14:05:25 ElectricSunrise pipewire[1994]: mod.jackdbus-detect: Failed to receive jackdbus reply: org.freedesktop.DBus.Error.ServiceUnknown: The name org.jackaudio.service was not provided by any .service files
Mai 29 20:15:34 ElectricSunrise systemd[1981]: Stopping pipewire.service - PipeWire Multimedia Service...
Mai 29 20:15:34 ElectricSunrise systemd[1981]: Stopped pipewire.service - PipeWire Multimedia Service.
Mai 29 20:15:34 ElectricSunrise systemd[1981]: pipewire.service: Consumed 39.208s CPU time, 30.0M memory peak, 0B memory swap peak.
-- Boot 461315349f334af3999a48eb82032410 --
Mai 31 15:25:08 ElectricSunrise systemd[2118]: Started pipewire.service - PipeWire Multimedia Service.
Mai 31 15:25:08 ElectricSunrise pipewire[2134]: mod.jackdbus-detect: Failed to receive jackdbus reply: org.freedesktop.DBus.Error.ServiceUnknown: The name org.jackaudio.service was not provided by any .service files
Mai 31 15:35:11 ElectricSunrise systemd[2118]: Stopping pipewire.service - PipeWire Multimedia Service...
Mai 31 15:35:11 ElectricSunrise systemd[2118]: Stopped pipewire.service - PipeWire Multimedia Service.
-- Boot b8f4e27c10e74498b17ec0d79e38419a --
Mai 31 17:08:48 ElectricSunrise systemd[1937]: Started pipewire.service - PipeWire Multimedia Service.
Mai 31 17:08:48 ElectricSunrise pipewire[1953]: mod.jackdbus-detect: Failed to receive jackdbus reply: org.freedesktop.DBus.Error.ServiceUnknown: The name org.jackaudio.service was not provided by any .service files
Mai 31 17:11:39 ElectricSunrise systemd[1937]: Stopping pipewire.service - PipeWire Multimedia Service...
Mai 31 17:11:39 ElectricSunrise systemd[1937]: Stopped pipewire.service - PipeWire Multimedia Service.
Mai 31 17:11:39 ElectricSunrise systemd[1937]: Started pipewire.service - PipeWire Multimedia Service.
Mai 31 17:11:39 ElectricSunrise pipewire[4963]: mod.jackdbus-detect: Failed to receive jackdbus reply: org.freedesktop.DBus.Error.ServiceUnknown: The name org.jackaudio.service was not provided by any .service files
Mai 31 17:14:23 ElectricSunrise pipewire[4963]: pw.node: (bluez_output.41_42_EF_C9_F9_1C.1-154) running -> error (Received error event)
and that please
pactl list sinks | grep "State:"
	State: IDLE
	State: RUNNING
To be sure and I don't think you are an idiot, but when you test the internal speaker you disable the bluetooth one?
Yes, i disable the bluetooth, reload the youtube page, check that the sound bar is at max in the menu on the bottom right, check that youtube is on max and none of those are muted.
Thats why im assuming its hardware at this point, no?
Edit: I also checked the pulse audio program and went through all the reasonable options and waited a bit.
not for now, I don't give up if you are agree ?
Im not sure i understand, not giving up sounds good, as long as you think your time is reasonably spent on this. Unfortunately im just a passenger in this and cant contribute much.
Ill be happy as can be though if I could work properly on this machine :wink:
great, give me the output of
pactl list sinks | grep -E "Name:|Description:|Mute:|Volume:|Active Port:|State:"
pactl list cards | grep -A4 "Active Profile"
Awesome :slight_smile:
	State: SUSPENDED
	Description: Built-in Audio Analog Stereo
	Mute: no
	Volume: front-left: 65536 / 100% / 0,00 dB,   front-right: 65536 / 100% / 0,00 dB
	Base Volume: 65536 / 100% / 0,00 dB
	Active Port: analog-output-speaker
	State: RUNNING
	Description: M7
	Mute: no
	Volume: front-left: 16513 /  25% / -35,92 dB,   front-right: 16513 /  25% / -35,92 dB
	Active Port: headphone-output
	Active Profile: output:analog-stereo+input:analog-stereo
	Ports:
		analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, latency offset: 0 usec, availability group: Legacy 1, availability unknown)
			Properties:
				port.type = "mic"
	Active Profile: a2dp-sink
	Ports:
		headphone-output: Headphone (type: Headphones, priority: 0, latency offset: 0 usec, available)
			Properties:
				port.type = "headphones"
edit: Should I disconnect from the bluetooth speaker (M7)?
yes for BT please for now
aplay -l
Okay bluetooth is off now.
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC256 Analog [ALC256 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
now that
amixer -c 0
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Playback channels: Front Left - Front Right
  Mono:
  Front Left: Playback 0 [0%] [-65.25dB] [off]
  Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Capture channels: Front Left - Front Right
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 63 [100%] [30.00dB] [off]
  Front Right: Capture 63 [100%] [30.00dB] [off]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Internal Mic Boost',0
  Limits: 0 - 3
test the sound with this
speaker-test -D plughw:0,0 -c2 -twav
Unfortunately nothing. This was in the terminal. I rebooted the PC and also nothing. Went through the Pulse audio and changed profiles under configuration and also nothing.
speaker-test 1.2.9
Playback device is plughw:0,0
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 64 to 1048576
Period size range from 32 to 524288
Using max buffer size 1048576
Periods = 4
was set period_size = 262144
was set buffer_size = 1048576
 0 - Front Left
OK gibe me the output of
dmesg | grep -iE "snd_hda_codec_realtek|autoconfig|speaker_out|line_out|hp_out"
and that
cat /proc/asound/card0/codec#0 | grep -iE "Codec|Subsystem Id|Vendor Id"
dmesg: read kernel buffer failed: Operation not permitted
Codec: Realtek ALC256
Vendor Id: 0x10ec0256
Subsystem Id: 0x17aa3345
an that please
this please
sudo dmesg | grep -iE "ALC256|autoconfig|speaker_out|line_out|hp_out|picked fixup"
cat /proc/asound/card0/codec#0 | grep -A12 "Node 0x14"
