Wouldn't it have been quicker to just reinstall your OS by now?
You can unselect those and keep them.
Remember, this is just a Reinstall of KDE...
Once you have removed the packages, you will want to remove KDE configs.
Then install KDE.
okay i have done that.
now next step ?
Check in ~/.config directory for any KDE or Plasma folders and remove them.
Once that is done, reboot then, install KDE Desktop again.
uhhh... yes.
where is this located, i found one in home folder.
i can't able to find kde or plasma folder here.
kde.org, latte...
sorry, i cant able to understand, what do you want to say ?
In your ~/.config, in the screenshot - you can see a folder named kde.org and another named Latte
okay i am deleting that.
Yes, you should restart after that.
Because those were removed...
Are you Logged IN on KDE While Doing This?!
i don't know.
No, I think the OP was using latte dock on their gnome environment as well.
