Zorin is running very slow
Fall back on Gnome Shell til you get it reinstalled.
my icon pack was just changed. what is going on :flushed: :flushed:
Remember above, marking Breeze Icons in Synaptic For Removal?
hmmm... yes....
Once it is complete... Log In On Gnome and reinstall latte and Plasma...
okay.
completed
now i am restarting... please wait 2 minutes 30 seconds
What is this, I has restarted and this came
Please help...
SDDM [sigh]
I guess it was not removed.
I have pressed enter and this screen came
And here in sessions there is no sessions.
Please help me :sob::sob::sob::sob::sob::sob::sob::sob::sob::sob::sob::sob::sob:
@Aravisian what is this, please help me.
When you click, the drop down arrow....you did not get "default session"?
Yes, I have clicked but there is nothing...
@Aravisian
Have you also deleted the gnome with plasma??
:crying_cat_face::crying_cat_face::crying_cat_face::crying_cat_face::crying_cat_face:
No. Unless you removed Gnome, It should Still be there.
Reboot.
Tap esc or tab or left shift to pull up Advanced Options for Zorin.
Enter recovery menu.
Arrow key down to Enable Networking' and enable it. Back to the Recovery Menu, arrow key down to Prompt` and drop to prompt
hit enter
In the prompt, enter in
sudo apt install kde-full
If you want to, you can reinstall the Zorin Gnome desktop in order to restore GDM3 over SDDM as well as ensuring all Gnome Files are in place;
Okay, I am going to the advanced option please wait for a second.
Do you mean root by terminal?
That's right.
Kde full is 979 Mb but my one-day limited data is only 2 GB so downloading that will be my big data wastage.
Okay there is no other way I have to do that.:sweat:
Does everything failed?
