4.7 GB the dvd
When i burnt it?
I've had something like yours some time ago because I forcibly turned off windows 10 bluescreen then I wanted to install the zorin os and I experienced a locked hard drive (like read-only mode/fast mode/fast startup). is your windows running normally? try to check the hard drive with CHKDSK and disable fast boot mode.
you have better specs than me.
Yeah, what about the DVD is just 4.7 GB is it the problem??
I don't know
No my windows is not
Zorin OS Core should be sized about 2.9 gigs...
Zorin OS Pro comes with both Core and Lite as well as extra applications; so is larger in size than Either Core or Lite.
I don't have fast boot mode
Okay and the solution??
If you read all messages pls give me the solution
Your RAM has not successfully performed a MemTest. I would focus my efforts there.
Yeah that's right thanks
Yes, that is the test to choose.
And my windows is not working now is it a problem
Okay, it didn't work like you see above
I think Aravisian knowledge or educated guess it heading in the right direction
Your error reading - "unable to read page block 3bed2c9e"
Causes and Solutions
These errors can be due to a variety of reasons:
- bad memory modules (solution: use memtest86+ to check your memory)
- a bad dvd drive (solution: if possible, try using a different cd/dvd drive)
- bad data cable (solution: change it for a new one)
- bad media (solution: try burning the iso image to a new disc)
- a corrupted iso image (solution: run an md5 checksum, and if they don't match, download the iso image again)
