Zorin OS 16 Core Installation Problem
The issue why you cannot installing Zorin could be a graphic card what could be problems with vram.
Okay I will listen to him
How??
Are you using a Nvidia Card?
No,internal intel and the external is AMD
The AMD is the problem
Then vRAM of Graphics would not apply in this case. (It was a good suggestion, though, Bourne).
What is the vRAM
And what is the solution
Replace the RAM...:neutral_face:
Really, okay that is it so
But in the case of Ubuntu i did install it good from the usb drive 28GB
this might be the problem
Are you saying that if i tried to install zorin from the usb drive it won't
you can try via flash instead of dvd.
It is worth trying.
I suspect RAM given your Windows and Linux errors both combined with an unsuccessful MemTest. But... it's as Bubby said, an educated Guess, based on limited information exchanged over the internet.
There is not harm in trying... other than general frustration.
Before 2 years i also tried to install it from dvd
The DVD itself is the evil?
Is secure boot off?
Maybe cuz ubuntu did installed well from the usb drive, is there a difference between zorin and ubuntu in installation?
