Is this a new install or was it working before? What's the make and model of the computer you're using? Did you install ZorinOS Lite or Core version? Did you use the "Try Zorin" option before you committed to installing it in the computer, and confirmed that everything worked?
In any case, here are some threads you can go through and hopefully help you with your issue:
I know that the AX201 wifi adapter is quite new, and I am unsure if it is supported in Linux kernel 5.4, but I am asking if anyone knows when Zorin will begin supporting this adapter out of the box installation? I am currently typing from windows and do not have Zorin installed since I have no other method of network except for wireless. I am hoping to be able to migrate to linux some time because of its outstanding stability and how it is an open source operating system built by the community. …
When I restart/shutdown, there's no sounds and the Audio Controller and Built In Audio is turned off. But when I turn both of them on, the sounds came back. How can I stop the Audio Controller and Built In Audio to turn off when I restart/shutdown the computer?
Where do I go to check sound settings?
I can see the vumeter moving in zorin sound settings when I perform a sound test but I can't heard nothing. If I plug a headset in jack I can hear the sound test.
I installed the pulse audio following other post solutions here, if some one can help me.
I don't remember in which zorin version did it stop working.
Thank you!
toni@hp-compaq-6730s:~$ sudo lshw -C sound
[sudo] contraseña para toni:
*-usb
descripción: Vídeo
producto: CKF7063
fabr…
system
Closed
August 13, 2023, 1:50pm
4
