Not going in to to much detail as I have wiped my drive and installed 16.3 again using my Rescuezilla back-up copy ..... I will attempt another update in a few days ..... took 4.22 hrs on 55 Mbps ..... but others have said it would take a long time ......
As some have discovered if you are not using Gnome DE the updater will not work .... not surprised ..... but my Gnome DE 16.3 Pro version does not have any desktop layout choices other then the one I will post in the photo below .....
I desperately need the one where the taskbar is at the bottom with the normal Z start button on the left hand side before I proceed with the updater again ..... bad enough trying a new OS version without having to fight with the desktop .....
By the way I could not get Cinnamon DE to install on 17 Pro so that wouldn't work for me ..... so I need the Gnome one fixed .....
I have no idea that happened to the Layout choices as I have been on Cinnamon DE with Zoroin 16.3 Pro for more than 2 years .....
It seems a lot of the issues with upgrade are due to conflicting packages. I've only run the upgrade twice, once on a virtual machine and once on hardware, both times successfully but there were barely any modifications or additional packages installed. The update took more than an hour for me, even on a wired connection. I'm a little worried that they've called it good on the upgrader before it's time.
Hi, another member posted a solution that worked for them. If you are running Cinnamon DE I would remove it for the time being and default to Zorin Desktop.
I have a Question: You wrote that You installed 16.3 again and that You will try an Update later. Why You didn't install directly Zorin 17? When it is installed You don't need to do an Update to Z17.
Can you see if the earlier option in the thread restores them that Aravisian offered as first one? Is it Core or Premium/Pro? Just checked your sig/profile and see it is pro in which case the commands are different. Hold on!
Oh and I think Pro upgrades need a payment? Not sure. You might need to contact Team Zorin on that question.
I have some 600 GB of info on that drive and I backup using Rescuezilla as my backup source ..... it makes a complete picture of your entire disk including the partitions with no options to pick and choose what you want to reinstall or not .....
This seemed like the best solution to me ..... I'll give it a try again soon but not tomorrow as we are scheduled for a 12 hrs brown out ....
Thanks I read the entire thread you posted gonna sleep on it as I've been at it since 5:30 am this morning and my brain needs to sleep ..... will work on this day after tomorrow as like I said we are getting a 12 hr brown out ..... for joy ......
I gave up on the direct upgrade and did a clean install, because I felt it was faster than trying to fix the problem. It may need the feature to be able to roll back before upgrading.
Due to my experience with Ubuntu upgrades in the past , I completely removed the budgie desktop I'd been using for two years and had pleasant upgrade experience. I had to come to forum here for some help to restore the default sessions to Zorin 16. @ Frog I hope the next upgrade attempt goes well !
Took about 1.5 hours to back up and 2+ hours to restore but it seems like something is slowing down my 1 TB external drive .....
I'm beginning to wonder if I'm not having a problem with my USB ports on my laptop ..... sometimes if I plug 2 more devices into the 2 free USB slots it will disconnect my USB WiFi mouse ..... never used to do that .....
Can't plug two 1 TB Passports into those slots anymore period as it shuts down both my WIFI dongle and my WIFI mouse now ..... again I used this type of setup for years .....
I am running a 4 port USB gadget plugged into 1 of my 3 laptop ports but again been running that set up for years ......
Yea it is a regular occurrence in the country I now live in (16 years now) ...... about once a month for them to do maintenance on the feeders ...... ya kinda get used to it ......
